Dovetail help
Forum topic by popmandude posted 989 days ago 765 views 2 times favorited 9 replies Add to Favorites Watch
View popmandude's profile
popmandude
111 posts in 1189 days
989 days ago
Hey everybody.
The time has come for me to learn how to cut dovetails by hand. The main thing I just can’t get my head around is how to make things come out even regardless of the width of the stock. If any one knows of a web site that explains the set up process in terms a simple mind can understand, please post it for me.
Thanks
Randy
9 replies so far
View rance's profile
rance
3856 posts in 1329 days
#1 posted 989 days ago
Randy, Google for “hand cut dovetails dividers” without the quotes (one link is www.woodworkersinstitute.com/print.asp?p=1382 ). On the other hand, I strongly recommend you just eyeball them. If you want them to look perfectly spaced, use a router jig. Maybe not in the beginning, but I think you’ll eventually agree that if the eye can see that they are not perfectly spaced (within reason), then you’ll like them better.
I also HIGHLY recommend Rob Cosman’s book and DVD on HCD. The best techniques I’ve seen.
View lew's profile
lew
8982 posts in 1924 days
#2 posted 989 days ago
http://www.blocklayer.com/Woodjoints/DovetailEng.aspx
http://www.handcutdovetails.com/
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View Gregn's profile
Gregn
1643 posts in 1152 days
#3 posted 989 days ago
Cool Calculator Lew, Thanks.
View randi's profile
randi
43 posts in 989 days
#4 posted 988 days ago
Wow that calculator with the printable template is a huge time saver. Thank you!
-- "A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of handguns and tequila." ~Mitch Ratcliffe
rance
#5 posted 988 days ago
Two nice links there (blocklayer & diyinfo).
View BertFlores58's profile
BertFlores58
1530 posts in 1091 days
#6 posted 988 days ago
The truth about handcut dovetails…. Any style or size will do but it needs to be fit. I had made dovetail joints in different joints: one of the difficult one is the tapered and the other is when the wood are of different thickness and texture. One thing for sure you must have a sharp chisel and dovetail saw. Here is a photo of the results:
different thickness of a dovetail joint
and here is the tapered joint:
I made a little practical video on cutting the dovetail using the edge of the vise…
video
hope this will help.
-- Bert
popmandude
#7 posted 988 days ago
Great info. Thanks folks
Randy
View Rick's profile
Rick
19 posts in 1904 days
#8 posted 987 days ago
After taking a woodworking class that covered hand cut dovetails – scribe, chisel, dovetail saw, I discovered some youtube videos that pointed out you can use a coping saw to remove most if not all the wood after you make your original cuts on the outlines. MUCH faster, and if you’re careful you can cut right to the line.
View RichClark's profile
RichClark
157 posts in 1599 days
#9 posted 986 days ago
There is some excellent DVDs from a maker in Devon England that teaches you step by step how to make them perfectly… I swear if I ever win the lottery I will study there.. They are not expensive and they are perfect reference.
He is a Maker/Designer…. This guy sells one off chairs for 40-60K…. and the DVD’s are shot in the shop with the apprentices taking notes. He has like 5-6 of them and I have them all they are brilliant.. straight forward and exacting… (key is exacting… they demand perfection!)..
Do a real web search on “DAVID SAVAGE” His bio is like like the tip of the who’ is who’s in fine woodworking…
Or just use a router and hope for the best.
Rich (sorry for the rant..) Its FUNNER to make them perfect by hand! really it is…..
-- Duct Tape is the Force! It has a light side and a dark side and it Binds the Universe together!
