Why is my planer doing this?
Forum topic by thomasfurman posted 01-22-2017 11:16 PM 555 views 0 times favorited 5 replies Add to Favorites Watch
View thomasfurman's profile
thomasfurman
22 posts in 644 days
01-22-2017 11:16 PM
My entire shop is 1940-50’s Delta and Atlas. I recently picked up a minty Delta 6” planer.
I watched a few tutorials on Youtube about adjusting the fences and went to work on mine.
The wood slides over the infeed fence, over the blades (removing only the smallest amount of material), and onto the outfeed fence perfectly…..until the VERY last inch of the board.
That is when I hear the blades really do some work (you can tell by the noise) and when I look at the board I can see how it gently took away some of the board’s cupping until that last inch when almost a 1/32” has been dug into the board.
Any idea how to fix this?
5 replies so far
View papadan's profile
papadan
3584 posts in 3516 days
#1 posted 01-22-2017 11:23 PM
That is what is known as Snipe, it can happen on either or both ends of the board. It is caused by the wood dropping lower that the cutters as it enters or exits the cutters. With no snipe on the input, you are almost there. Raise the outside edge of the output table just a little bit and try it. What actually causes this is the weight of your wood, it will push down the outer edge of your infeed or outfeed tables, adjust them up slightly to compensate for this.
thomasfurman
#2 posted 01-22-2017 11:29 PM
- papadan
so just to clarify….while facing the planer…adjust the left (outfeed) table up a hair? I’ll try it thanks!
papadan
#3 posted 01-22-2017 11:35 PM
Yes adjust the outer most edge, up just a little and try it.
View rwe2156's profile
rwe2156
3092 posts in 1628 days
#4 posted 01-22-2017 11:41 PM
I think you’re talking about a jointer, not a planer.
Sounds like your outfeed table is too low.
Put a straight edge on the outfeed and with the jointer blade at TDC it should just touch.
papadan
#5 posted 01-22-2017 11:47 PM
Lots of people call them Planer/Jointers, even the manufacturers.
