What TPI do you use for bandsaw boxes?
Forum topic by Steven H posted 09-05-2010 04:36 AM 1155 views 0 times favorited 4 replies Add to Favorites Watch
View Steven H's profile
Steven H
1117 posts in 3059 days
09-05-2010 04:36 AM
Im cutting very tight curves on a 3” pine wood.
Its is very difficult to cut with a 3/16 blade. The blade is struggling.
It is an brand new Olson All Pro bandsaw blade.
Is it because the wood I’m using?
View Gregn's profile
Gregn
1642 posts in 2982 days
#1 posted 09-05-2010 06:32 AM
What do you mean the blade is struggling? Is the blade drifting or is it bogging down? Have you tried changing blade speeds on your band saw? Is the tension tight enough for the blade? I suspect you might be feeding the stock to fast and that your not allowing the blade to work on its own so its binding on you.
View tooldad's profile
tooldad
660 posts in 3714 days
#2 posted 09-05-2010 06:41 AM
The amount of teeth affect the speed and quality of the cut. If you go with a 4tpi then you will get a faster cut. That is what we use in the school shop. It makes the kids sand a little more, but is more forgiving on the impatience of a teenager. More tpi will give you a smoother, but slower cut.
Steven H
#3 posted 09-05-2010 07:59 AM
Greg
You are correct, I am feeding it too fast.
And it is fluttering a bit.
View richgreer's profile
richgreer
4541 posts in 3074 days
#4 posted 09-05-2010 03:43 PM
Many people do not have their blades tight enough. If you are using the markings on the side of your bandsaw to set the tension it is quite likely the blade is not tight enough.
The ideal tension for most blades is 20,000 lb/sq in. On my 18 inch Jet with a 1/4 inch blade, I need to set the tension, per the markings on the side of the saw, as if I was using a 5/8 inch blade. Of course, every saw is different.
You can buy (or many borrow) a tension gauge to test your saw. Many woodworking clubs have tension gauges the members can borrow because once you know the right settings, you really don’t need the gauge for a while. You may want to retest after a year or more because the springs will get weaker with age.
