220 Volt, Table Saw Switch Question
Forum topic by BTKS posted 09-05-2010 03:58 AM 3741 views 0 times favorited 6 replies Add to Favorites Watch
View BTKS's profile
BTKS
1986 posts in 3432 days
09-05-2010 03:58 AM
Topic tags/keywords: question
All,
I am wondering about my table saw switch. It was making a humming or buzzing noise today when the saw was turned off. The sound reminded me of an electric motor that won’t start, just locks up and buzzes. I pulled the plug and the noise stopped. It was real faint, I only heard it when everything in the shop was shut off and no background noise. The thermal breaker did not trip and there were no abnormal functions.
Hope someone knows if my switch is about to go kaput or if it might be normal.
Thanks, BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View snowdog's profile
snowdog
1164 posts in 3950 days
#1 posted 09-05-2010 02:05 PM
I am no electrician but sure do tinker.
Sounds like a short. If you took the switch apart and do not see anything wrong (wires, dust, moisture) I would consider changing (replacing) the switch. Is the polarity correct?
View lew's profile
lew
12019 posts in 3723 days
#2 posted 09-05-2010 03:52 PM
The switch is probably a “magnetic starter” type. There are electromagnets in it that may be vibrating. This could occur if their mounting screws get loose. You could pull the plug, open the the starter and tighten any MOUNTING hardware. There are ADJUSTMENT screws that should NOT be turned!
View MedicKen's profile
MedicKen
1612 posts in 3430 days
#3 posted 09-05-2010 04:21 PM
I agree with Lew that it most likely is a magnetic starter. I would check to see that all of the wiring connections are tight as well as the mountings. A loose connection can cause the noise as well as a fire hazard. Magnetic staters also have a set of contacts that over time can become pitted and corroded. take a look at the contacts and see if they are burnt, they can be cleaned up with some disassembly and filing/sanding. If you dont feel comfortable in disassembling and or cleaning the contacts call a qualified electrician. Here is a short article on cleaning the contacts.
View BTKS's profile
BTKS
#4 posted 09-05-2010 05:53 PM
Thanks all,
The switch is a magnetic starter. Power is interrupted to the saw, the switch defaults to the off position. I’ll give it a try. Either way the worst case scenario is replacing the switch.
MedicKen, Thanks for the link, going there now.
BTKS
View lew's profile
lew
#5 posted 09-06-2010 12:27 AM
Grizzly has some pretty reasonable replacement magnetic starters.
View EEngineer's profile
EEngineer
1102 posts in 3581 days
#6 posted 09-06-2010 02:50 AM
It could indeed be a magnetic starter. I looked at a few of these to determine how they work. The Delta unit I looked at, to give flexibility with a wide range of voltages, used a step-down transformer to energize the contactor. Rather than changing the contactor coil for different motor voltages, you just moved a tap on the transformer to adjust the motor voltage down to 24 VAC (IIRC) to drive the contactor coil.
The transformer is always driven even if the motor and contactor are not. If the laminations on the transformer are loose then it will buzz. It doesn’t necessarily indicate a faulty transformer or anything dangerous.
