Finishing Red Oak-- I Need An Oil Finish That Will Last
Forum topic by Vinnie posted 09-05-2010 01:34 AM 3030 views 0 times favorited 4 replies Add to Favorites Watch
View Vinnie's profile
Vinnie
101 posts in 3507 days
09-05-2010 01:34 AM
Topic tags/keywords: resource tip question trick oak scroll saw drill press sander blade finishing scrollworking sanding arts and crafts
Hello, I make a lot of my projects out of red oak and I want to use a oil finish that does not dry up. I have used lemon oil and mineral oil. Both of these oils dry up in a few months to the point that my projects almost look white. When I redo them with mineral oil I get the same results after a few months.
The project that I make are 3D and the parts move in and out so I can’t use brush on polys or spray finishes.
The same goes for the wood trivets that I make. I am looking for and oil finish that will last.
Can someone help me?
Thanks, Vinnie
-- Personalized name signs, Ham Radio Call Signs signs, home decor and more! http://www.kerflinecrafts.etsy.com
View closetguy's profile
closetguy
744 posts in 4010 days
#1 posted 09-05-2010 03:13 AM
Try danish oil.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View Glen Peterson's profile
Glen Peterson
556 posts in 3174 days
#2 posted 09-05-2010 03:17 AM
Try Waterlox original. I’ve used it on both furniture and turned pieces and have been verfy happy. It’s similar to wipe on poly. I lather on the first coat. Let it soak for 30 minutes. Then wipe it completely dry with a clean rag. After it dries I rub it out with 0000 steel wool (although I most recently tried an abrasive pad that works similarly). Subsequent coats go on and then are wiped off 5-10 mins later. Be sure to wipe off completely dry. Then use steel wool again. I typicaLLY do 3 or more coats. For turned pieces I then buff.
-- Glen
View Wolffarmer's profile
Wolffarmer
407 posts in 3356 days
#3 posted 09-05-2010 04:25 AM
I like to use Tried and True danish oil
Randy
-- That was not wormy wood when I started working on it.
Vinnie
#4 posted 09-05-2010 05:35 AM
Thanks closetguy,Randy and Glen! I will try the Waterlox and the Danish oil to see which one I like best.
Thanks for replying to my post.
Vinnie
