Frame Backings?
Forum topic by nurvreck posted 09-04-2010 07:46 PM 1064 views 0 times favorited 5 replies Add to Favorites Watch
View nurvreck's profile
nurvreck
80 posts in 2989 days
09-04-2010 07:46 PM
Topic tags/keywords: question frame backing hardboard
I’ve got a question about what everyone uses for backing on frames, shadow boxes, etc. When I built my first shadow box, I used foam board for the mounting and just cut out some hardboard for the actual backing. I made some more frames to put awards in and continued with the hardboard. Is there likely to be an issue with this? Should I be using some type of acid free backing or barrier between the two or something besides hardboard? I have a friend who wants some frames for Blue Angel pictures but want to make sure I’m not going to use something that will eventually ruin the pic. Thanks in advance for your help.
-- Dan, SSgt/USMC, Yuma, AZ http://thefamelesswoodworker.com
5 replies so far
View Gregn's profile
Gregn
1642 posts in 3102 days
#1 posted 09-04-2010 08:45 PM
For shadow boxes I use 1/4” Luan. My wife use a type of foam board with adhesive to mount her counted cross stitch to so I can mount them into frames. You can get this at Hobby Lobby or any crafts store. Don’t know if that helps any.
View Lee Barker's profile
Lee Barker
2170 posts in 2969 days
#2 posted 09-04-2010 09:32 PM
I’d pose that question to a frame shop or maybe there is the LJ equivalent in that realm. It will feel good to know for sure.
View lew's profile
lew
12267 posts in 3874 days
#3 posted 09-05-2010 01:31 AM
For picture frames, I use acid free foam board. For larger shadow boxes, a piece of 1/4” plywood/luan as the actual back but add a piece of acid free foam board or acid free mat as a separator between the articles and the wood..
16276 posts in 4337 days
#4 posted 09-05-2010 03:59 AM
For regular frames, I don’t understand why you need any backing other than the foam board. That’s all I use.
View whit's profile
whit
246 posts in 4095 days
#5 posted 09-05-2010 04:39 AM
For smaller stuff I use foam board. For the larger stuff, I use multiple layers of foam board primarily to keep it from warping. So far, it’s worked OK. Check back with my grandkids in about 30 years. ;)
Since you’re talking about mounting actual pictures, you should seriously consider useing acid-free mat board to keep the glazing (glass or acrylic) from contacting the picture or they will likely, at some time, become one. I understand this has nothing to do with the backer board but it will definitely ruin the picture.
Whit
-- Even if to be nothing more than a bad example, everything serves a purpose. cippotus
