Need help!
« back to Hand Tools forum
Forum topic by Dutch308 posted 01-22-2017 03:52 AM 654 views 0 times favorited 10 replies Add to Favorites Watch
View Dutch308's profile
4 posts in 422 days
01-22-2017 03:52 AM
Hello all, I am new here and could use some help! I’m looking for a tool like this but having no luck! Any help would be appreciated!
10 replies so far
View fuigb's profile
471 posts in 2889 days
#1 posted 01-22-2017 05:38 AM
What is it?
-- - Crud. Go tell your mother that I need a Band-aid.
4 posts in 422 days
#2 posted 01-22-2017 11:03 AM
It’s used to trace the outline of objects that don’t set flush to the surface of the tracing paper allowing you to make a more accurate trace.
View EricTwice's profile
230 posts in 465 days
#3 posted 01-22-2017 11:23 AM
looks simple enough, why not make it?
-- nice recovery, They should pay extra for that mistake, Eric E.
4 posts in 422 days
#4 posted 01-22-2017 12:11 PM
That’s what I’m probably gonna do. I’ve dug all through the net and doesn’t seem to be any out there!
View dhazelton's profile
2719 posts in 2228 days
#5 posted 01-22-2017 01:06 PM
Probably as close as you’ll come today.
View jerryminer's profile
908 posts in 1373 days
#6 posted 01-22-2017 08:03 PM
Another “modern” version:
4 posts in 422 days
#7 posted 01-22-2017 08:58 PM
Jerry that looks like it might work, I’ll give it a look! Thanks
View Dan Krager's profile
Dan Krager
3902 posts in 2166 days
#8 posted 01-23-2017 03:02 AM
Then there’s this thing...
And I built almost exactly what you described above using a block of wood, slanted hole for pencil, and a vertical “ruler” with a “sharp” edge. It was actually a strip of acrylic with a taper ground on the scribing edge to align with the pencil point. It is a bout 12” tall for larger turnings etc. Don’t have a picture but could get one if you’re interested.
-- Dan Krager, Olney IL Just when you figure out where things are in the hardware store, they rearrange the store.
View bridgerberdel's profile
50 posts in 1174 days
#9 posted 03-01-2017 04:09 AM
Linoleum underscribe marker
-- occasional musings on my blog:
View waho6o9's profile
8130 posts in 2509 days
#10 posted 03-01-2017 04:16 AM
Simple scribe works well and it’s around 10.00 USD
