| Forum topic by itsme_timd | posted 261 days ago | 269 views | 0 times favorited | 13 replies | ![]() |
261 days ago |
Topic tags/keywords: question oak bandsaw sander shaping arts and crafts I’m cutting some corninces for a table and I drew out the arc and rough cut on the band saw. The rough cut has some bumps/waves along the surface. Can someone tell me the best way to remove these? I’ve tried a belt sander inverted in a bench vise, a card scraper, hand file and sandpaper – I just seem to be making my piece smaller and smoothing the bumps! -- Tim D. - Woodstock, GA |
261 days ago |
That’s what I want an oscillating spindle sander for. It’s perfect for the inside of curves. A disk sander does the job on outside curves. -- Gary, East TX -- The longest journey begins with a single step. |
261 days ago |
Inside = spindle sander Outside = disc or belt sander -- -John "Do I have to keep typing a smiley? Just assume it's a joke." www.flickr.com/photos/gizmodyne |
261 days ago |
Gizmo’s got it. . . and like Gary, I’m wanting an oscilating spindle sander. Sanding drums in a DP only get you so far. That’s what I currently go to, however. -- Jeff, South Carolina |
261 days ago |
Yep, got the OSS. works fine on inside curves. -- Thos. Angle, Owyhee Design, Oregon |
261 days ago |
Yes an OSS can do wonders, but it also can create more bumps because of its small size (unless you have a huge one). A piece of masonite (or other semi-flexible wood), say eight inches long and one inch wide, with sandpaper glued on on one side and two small handles glued on the other side will make a flexible sanding strip. David Marks uses this techninque all the time. Neil Lamens uses a strip of Wiggle Wood inside a sanding belt to smooth large curves. Steve -- Stevethepeeve -- I'm no rocket surgeon |
261 days ago |
The other way is to make a template from MDF or similar material. Smooth with sanding strip or rasp or whatever (the mdf should shape easily). Then attach template to the other pieces and use a flush trim router bit to match the profile. -- -John "Do I have to keep typing a smiley? Just assume it's a joke." www.flickr.com/photos/gizmodyne |
261 days ago |
gizmodyne hit it on the head for a cheaper way to clean it up quickly. Although if the jobs gets you an OSS go for it. -- Hope Never fails |
261 days ago |
I’d probably go with the template and flush trim router. -- Maplewood, MN |
261 days ago |
Router would have been my suggestion. Good luck and take some pics to post. Have a great day, -- Bob Lance, DE |
261 days ago |
Thanks all, now I see why that Ridgid spindle sander was so popular as a Christmas gift! -- Tim D. - Woodstock, GA |
261 days ago |
And… thanks again. I purchased a flush cut bit on my lunch break today… hopefully that will do the trick. I’d still like the spindle sander so I’ll add that to my ever-growing list. -- Tim D. - Woodstock, GA |
261 days ago |
like steve i use a metal or plastic ruler with sandpaper on it . it mostly depends on the lenth of the arch . im going to start one this week thats 7 ft. wide ill probably cut a piece of maple 1/8 thick 1 in wide glue sandpaper on it |
260 days ago |
If the arc happened to be part of a circle I would have started with a tramel and eased the bit through the work about a 1/4” at a time. If the arc was other than a circle then a template and router is the best way to go as mentioned above. Cheers -- A mind, like a home, is furnished by its owner |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1222 |
1653 |
119 |
333 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
923 |
LumberJocks.com Site Feedback
268 |
