Need help with finishing pine "sanded" plywood
Forum topic by NicP posted 01-21-2017 10:35 PM 735 views 0 times favorited 6 replies Add to Favorites Watch
View NicP's profile
NicP
3 posts in 634 days
01-21-2017 10:35 PM
Topic tags/keywords: question pine finishing sanding
Hi everyone. I’m new here and just having some fustration with a project. I am building some storage and shelves for my garage and i had some extra 3\4 pine “sanded” plywood. Well I am trying to get it smooth and cant figure it out i sanded it with 220 but it just doesnt come out smooth no how much i try. I would like to paint it white. The finish doesnt have to me mirror finish i just want it to look decent. I put some killz oil based primer on it and sanded and then did it again but it just still isnt even close to smooth in the rough areas. Hindsight i should have just went with birch plywood but i didnt know this was gonna be such a hassel? My next attempt was going to be to try and smooth it out with puddy. Is this a good idea or not? Any advice and help would be greatly appreciated.
View Kirk650's profile
Kirk650
566 posts in 892 days
#1 posted 01-21-2017 11:25 PM
I’d work it over with a good ROS, probably starting with 150 and then using 220. Surely it’ll smooth out.
View Madmark2's profile
Madmark2
392 posts in 732 days
#2 posted 01-21-2017 11:45 PM
Skin is not thick enough to sand. The more you sand the worse it will get. Spackle a skim coat and paint it with a nice thick enamel – two coats!
M
View NicP's profile
NicP
3 posts in 634 days
#3 posted 01-22-2017 12:09 AM
Thanks for help man! Seemed pretty good after that. Next time i will buy some better wood for sure. haha
View Millertime24's profile
Millertime24
6 posts in 682 days
#4 posted 01-22-2017 01:25 AM
Sanding sealer should help as well.
-- -Mike
View rwyoung's profile
rwyoung
409 posts in 3616 days
#5 posted 01-23-2017 04:47 PM
I’ve used BIN primer, the stuff that is shellac based. You can tint it a little too. Worked great on inexpensive plywood when making shop cabinets. If there are voids in the ply, some bondo or water putty or similar. Sand, prime, light sanding and then enamel.
Sprays easily and quickly. Drys very quickly too so nearly everything can be completed in one (long) day.
-- Don't sweat the petty things and don't pet the sweaty things.
View MrRon's profile
MrRon
5086 posts in 3387 days
#6 posted 01-23-2017 05:37 PM
You should apply a coat of shellac (the dewaxed type). Once dry, lightly sand with 220; repeat and then apply your paint
