Trying to Make Window Stop Molding with My Router Table
Forum topic by Pete_LJ posted 01-21-2017 01:07 AM 1266 views 0 times favorited 3 replies Add to Favorites Watch
View Pete_LJ's profile
Pete_LJ
102 posts in 942 days
01-21-2017 01:07 AM
Hi there:
I am trying to make a full set of window stop molding (about 120 LF) for a condo we own which is about 90 years old. The window stop molding holds the lower window sash in place. The existing molding is so beat up and broken it cannot be reused or repaired. Instead I would like to make new molding in a similar size and style as the original molding. However I cannot seem to find the right router bit for this project (perhaps I need two router bits and create the molding in two steps. Any input would be greatly appreciated. Pictures of the existing window stop molding are set forth below. The existing molding is 1/2” thick x 1 5/8” deep.
3 replies so far
View Harryn's profile
Harryn
74 posts in 2784 days
#1 posted 01-21-2017 01:24 AM
This is a standard ogee shape. bits are available from almost any mfr.
View JBrow's profile
JBrow
1366 posts in 1116 days
#2 posted 01-21-2017 01:55 AM
Pete_LJ,
The profile looks similar to what MLCS calls a Traditional Table Edge router bit. Perhaps one of the two offered by MLCS is close enough to get you going.
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bit_table_edge.html
Pete_LJ
#3 posted 01-21-2017 02:25 AM
JBrow:
Thank you very much, I did not realize that the required bit was called a table edge bit. Now that I know that I have found several possibilities. Once again, your help is greatly appreciated,
