Coupler for 1/2" copper pipe to 1/4" NPT?
Forum topic by Keith Kelly posted 01-20-2017 11:06 PM 1977 views 0 times favorited 10 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
279 posts in 1903 days
01-20-2017 11:06 PM
Up until now, I considered myself a decent googler. However, I am having a tough time finding the connection to go from 1/4” NPT (air hoses) to copper pipe. I found a set of about 4 adapters that would work at the hardware store, but that seemed excessive.
Can somebody point me in the right direction?
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com ... http://www.KeithsTestGarage.com
10 replies so far
View papadan's profile
papadan
3584 posts in 3608 days
#1 posted 01-20-2017 11:28 PM
Any hardware or home store(HD/Lowes) has Sharkbite fittings. The slide onto the copper pipe and gives you the male or female threaded end to connect hoses or other fittings to. They also have straight splices for joining lengths of pipe together. If you can’t sweat solder the fittings onto the pipes then Sharkbites are for you. I use them all the time.
View BorkBob's profile
BorkBob
127 posts in 2932 days
#2 posted 01-20-2017 11:46 PM
copper “pipe” is actually tubing and is measured on the outside diameter. Pipe is measured on the inside diameter.
1/2 copper tubing is 5/8” OD
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
papadan
#3 posted 01-20-2017 11:59 PM
I’m sorry BorkBob, but…... this is tubing and…...... This is pipe.
View OSB's profile
OSB
147 posts in 766 days
#4 posted 01-21-2017 12:23 AM
I prefer Swagelok fittings.
View TheFridge's profile
TheFridge
10818 posts in 1726 days
#5 posted 01-21-2017 12:53 AM
You may have to something like a 1/2pipe to 1/2 npt male to 1/2 npt coupling to 1/2 npt x 1/4 npt reducer. Or a 1/2 X 1/4 swage if you need a male thread at the end.
View Tony_S's profile
Tony_S
953 posts in 3323 days
#6 posted 01-21-2017 10:10 AM
One of these.
http://www.supplyhouse.com/Elkhart-30320-1-2-x-1-4-Copper-x-Male-Adapter
And one of these.
http://www.homedepot.com/p/Husky-1-4-in-FNPT-x-1-4-in-I-M-Steel-Coupler-C20HOM/205332142
Bobs yer uncle….your welcome;)
Any half decent plumping outfit should stock the adapter….
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View diverlloyd's profile
diverlloyd
3288 posts in 2097 days
#7 posted 01-21-2017 02:51 PM
1/2”cu by 1/4” cu reducer and a 1/4” cu by 1/4 fip. That would be what I did but I had it laying around. Those are solder joints you can also order a 1/2”cu by 1/4” fip but you would need to call around. If your air hose base a female end the you would need mip instead of fip.
View splintergroup's profile
splintergroup
2511 posts in 1462 days
#8 posted 01-21-2017 03:55 PM
All my shop airlines (3/4” copper) are terminated with 1/2” MPT solder-on fittings. I then use the standard brass adapters to reduce it to the size needed (plus thread sealer/tape).
View RogR's profile
RogR
113 posts in 1105 days
#9 posted 01-22-2017 03:06 PM
No dog in this fight, but curious as to why you run copper pipe for air supply?
splintergroup
#10 posted 01-22-2017 03:11 PM
- RogR
Easy to work with and install, corrosion resistant (water vapor in the lines), malleable in case it bursts or gets dinged, etc.
Plenty of other options for fixed lines and given the current prices of copper, I’d probably use something else today.
Galvanized or other steel pipe has rusting issues which can send small flecks of rust into the air stream.
