Jobsite Table Saw
Forum topic by stshy posted 01-20-2017 09:15 PM 708 views 0 times favorited 7 replies Add to Favorites Watch
View stshy's profile
stshy
1 post in 571 days
01-20-2017 09:15 PM
I was thinking of buying a table saw but am thorn between two. The dewalt DWE7480 at 400$ and the King Canada KC5100C at 319$. The dewalt is smaller and lighter and I have seen good reviews. The king canada I have not seen very reviews if any. Does anyone have the King Canada saw and recommend it? Thanks
7 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3792 days
#1 posted 01-26-2017 01:49 AM
I have a King drill press bought many, many years ago (late last century 80s ish) and it is going as well as the day it was brought to the shop. Don’t undervalue a bigger table top as it can make working so much easier. Space in front of the blade and to either side is valuable real estate!
View Lt_scout's profile
Lt_scout
37 posts in 651 days
#2 posted 01-26-2017 06:47 AM
I’m with Mark, I realize now the many shortfalls of a jobsite saw vs (any table saw) It mostly comes down to table surface space. Fence accuracy, smoothness of tilt/lift controls, cast iron top etc is bonus stuff.
-- When you know you can do more with less, you will require less to do more.
View ihadmail's profile
ihadmail
66 posts in 593 days
#3 posted 01-26-2017 07:25 AM
I have a Dewalt 7491RS and for the most part love it. The only real complaint I have about the saw is the limited space in front of the blade for making cross cuts.
Sorry I can’t comment on the King Canada brand though.
View rwe2156's profile
rwe2156
3033 posts in 1560 days
#4 posted 01-26-2017 03:26 PM
Truthfully a JS saw is a table saw in name only. You may have extreme space limitations you don’t say, but depending on what level of ww’ing you plan to do, something like dados not very feasible on a JS saw.
That being said, I’ve seen people build them into a large table and make a DIY fence that might get you by for a while.
For similar money I suggest looking for a used contractor saw with an induction motor on it.
View RogR's profile
RogR
111 posts in 945 days
#5 posted 01-27-2017 01:38 AM
- rwe2156
This is good advice. I have an older Dewalt JS saw and its a tough and light kickass saw for the jobsite but I wouldn’t want to actually “make” anything with it. I upgraded from a contractor saw to a cabinet saw and the former was streets ahead of a JS saw.
View Gadabout55's profile
Gadabout55
27 posts in 1990 days
#6 posted 01-27-2017 02:25 AM
I’ve had a DeWalt 745 for about 6 years and it has worked very well for me. I don’t have room for anything bigger, so it was either a jobsite saw or nothing. Definitely was the right choice for my situation. Can’t use a dado stack, but that’s ok by me.
View MT_Stringer's profile
MT_Stringer
3172 posts in 3311 days
#7 posted 01-27-2017 02:42 AM
I have the little DeWalt. So far, it has performed as needed. The table is not very big so some outfeed support would be a good idea if’n you are ripping material.
I like the rack and pinion fence adjustment.
My Incra miter gauge fits the miter slot.
Good dust collection when hooked up to a shop vac.
Loud when compared to my cabinet saw. :-)
Note: The arbor is short so a dado stack wouldn’t work. I did manage to safely bolt on two 7 1/4 inch rip blades with a shim so I could cut some drawer bottoms. That worked great, but there just aren’t enough threads for anything else.
Overall, I like it.
Hope this helps.
Mike
Set up at job site
Big difference in size! :-)
—-Short arbor
—-Rip blades for cutting drawer bottom slot.
