rec on face frame with stained birch plywood
Forum topic by Carol posted 01-20-2017 02:21 PM 625 views 0 times favorited 5 replies Add to Favorites Watch
View Carol's profile
Carol
62 posts in 711 days
01-20-2017 02:21 PM
Topic tags/keywords: custom closet birch stain
before i start buying my wood, i’m working on the final dimensions for a custom closet. i plan on using 3/4” birch plywood for the carcass and shelves. not sure what kind of wood to use for the face frames since i want to stain (light) or clear coat the entire project. not all the face frames are in the image below, had to break for dinner lol
recommendations pls?
-- Carol
5 replies so far
View Halc's profile
Halc
146 posts in 1800 days
#1 posted 01-20-2017 02:59 PM
Nice design and drawing. If you’re able to mill boards yourself, you could use birch for the face frames. It’s not my favorite wood to use (tear out, twisting & bowing, blotching), but it’s an economical hardwood. You say you would like the stain to be light, but if you made the finish on the face frame contrast with the carcass and shelves you could use any wood available to you. Since the colors wouldn’t match you wouldn’t need to have the grains matching either. You could also stain the carcass and paint the face frames. Good luck, it looks like a fun project.
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3911 days
#2 posted 02-19-2017 01:12 AM
An interesting project. Would a cherry or walnut work as a contrasting facing wood?
View Luthierman's profile
Luthierman
221 posts in 1285 days
#3 posted 02-19-2017 02:02 AM
What about going frameless and using prefinished edge banding?
-- Jesse, West Lafayette, Indiana
View mrbob's profile
mrbob
182 posts in 767 days
#4 posted 02-19-2017 03:16 AM
Birch looks nice with MinWax Natural stain or BLO cut with mineral sperits wipe on wait a few minutes wipe of excess, let dry and then your clear coat. Ya face frames soft maple stained or dyed darker.
View TungOil's profile
TungOil
1057 posts in 693 days
#5 posted 02-19-2017 03:37 AM
Consider using pre-finished birch ply for the carcasses, You can save yourself a lot of work. Then you can put anything you like on the front for the face frames. If you are looking for a lighter look perhaps maple?
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
