keeping wood moist
« back to Woodcarving forum
Forum topic by Karda posted 01-19-2017 09:33 PM 627 views 0 times favorited 14 replies Add to Favorites Watch
View Karda's profile
Karda
1115 posts in 580 days
01-19-2017 09:33 PM
I am going to have my maple tree trimmed this summer and want to save some wood for carvng. I won’t use it fast and there are others I want to try to get. Is there a way to treat the wood so it lasts longer than it would drying naturaly in a out of the weather shaded area. Thanks Mike
14 replies so far
View papadan's profile
papadan
3584 posts in 3395 days
#1 posted 01-19-2017 09:42 PM
If the logs dry too fast they will crack. To slow the drying process and prevent cracking or splitting all you need to do is paint the ends with latex house paint. They make stuff just for this, but paint is by far the cheapest and works just as good.
Karda
#2 posted 01-20-2017 04:13 AM
ok thanks, I was wondering if it would slow the prosses down more by wraping in plastc
papadan
#3 posted 01-20-2017 04:35 AM
Don’t do that!!!!! wrapping will hold in the moisture and the wood will rot. Just leave the bark on and paint the ends.
Karda
#4 posted 01-20-2017 04:59 AM
ok
View EngineerChic's profile
EngineerChic
34 posts in 531 days
#5 posted 01-20-2017 01:01 PM
Did you want to try spalting some of it? That would keep it moist and takes weeks to months (from what I’ve read online, never tried this myself). It would be a fungus-y science project, but might turn out pretty neat.
Karda
#6 posted 01-20-2017 04:48 PM
what is spalting, I have seen that term
View Andybb's profile
Andybb
1022 posts in 630 days
#7 posted 01-20-2017 06:00 PM
“Spalting is any form of wood coloration caused by fungi. Although primarily found in dead trees, spalting can also occur in living trees under stress or even in thriving trees.”
I’ve done a couple of projects with naturally spalted maple but apparently you can also DIY…(which I never knew until now, thanks)
http://www.finewoodworking.com/2009/04/14/spalt-your-own-lumber
-- Andy - Seattle USA
Karda
#8 posted 01-20-2017 06:35 PM
thats interesting thanks for the information
View jdh122's profile
jdh122
1018 posts in 2844 days
#9 posted 01-20-2017 06:36 PM
I’ve tried to keep wood moist by using plastic bags, and I discovered it’s a bad idea. Quickly develops fungus and starts to rot. You can, however, keep it moist by submerging it in water. I read about Windsor or post-and-rung chairmakers doing this and have tried it a couple of times, without any ill effects that I could detect.
-- Jeremy, in the Acadian forests
Karda
#10 posted 01-20-2017 06:38 PM
the watyer submersion sounds like a way thanks Mike
papadan
#11 posted 01-20-2017 06:47 PM
Water submersion is the way if you want to bend wood, you can also use steam. Karda, you want to dry your logs, just not too fast!
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 1891 days
#12 posted 01-20-2017 06:59 PM
My spouse just spits on it a little that seems to do the trick.
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
View MrUnix's profile
MrUnix
6767 posts in 2226 days
#13 posted 01-20-2017 07:56 PM
If you want to get spalting, then just let it sit out in the elements for a while before processing. Depending on species and weather conditions, it can take as little as a few weeks. Just keep it off the ground, as it will hold moisture and start to rot prematurely where it does contact the soil. Once it’s spalted to your satisfaction, bring it under cover and let it dry out normally. You can get some really dramatic results, and it doesn’t cost anything but time :)
Karda
#14 posted 01-20-2017 10:45 PM
ok
