Best way to attach shop vac to Bosch ROS65VC-6?
Forum topic by Dagobah posted 01-19-2017 05:48 PM 772 views 0 times favorited 7 replies Add to Favorites Watch
View Dagobah's profile
Dagobah
71 posts in 717 days
01-19-2017 05:48 PM
I’ve got a Ridgid shop vac with a 2.5” hose. I’m trying to connect it to my new Bosch ROS65VC-6
The sander comes with an adapter that fits either 1-1/4-In. and 1-1/2-In. hoses.
Am I better off using my existing hose (it’s not terribly flexible) and an adapter or going with a different hose all together? The 2.5” hose works great with my router table, so there’s a tradeoff either way. Looking for input from anyone with a similar setup.
7 replies so far
5015 posts in 2547 days
#1 posted 01-19-2017 06:37 PM
I have a Bosch 3725 which I think is a predecessor to the one you have. I run it with the 1 1/4” ID hose and found it to be about as good a compromise as you can get. You still have plenty of vacuum, and the hose is small/flexible/not obtrusive enough to work well while you’re moving the sander around. At one point I tried a Bosch 1” hose they sell for it and found it so lacking in air movement (suction) and a really annoying high pitched whistle I threw it away after one use. I could never get the 2 1/2” hose adapted to the sander, though if I had it would no doubt be unusable just due to the size. Besides, at least with mine, you can have too much suction. Even with the 1 1/4” hose I need to throttle back the vac a little. At first I just vented the hose at a connector. Eventually I bought a vac with variable speed. The reason I need to reduce the suction was that it was actually pulling the sander into the wood with a lot of force. this was not only putting a load on the sander, but it will overheat and ruin your H&L pads. So my advice would be to get the 1 1/4” hose, and check whether the sander is being overloaded (they may have changed the design from my model).
View Quikenuff's profile
Quikenuff
64 posts in 923 days
#2 posted 01-19-2017 07:42 PM
You’ll be much happier with a smaller hose 1 1/4” – 1 1/2” and this adaptor: Bosch VAC024
Your sander might have come with one.
I swap between 2.5” and 27mm hoses on festool CT26 all the time for various tasks, it’s not that big of a deal.
Quik
Dagobah
#3 posted 01-19-2017 07:50 PM
Yes, the sander came with the adapter. And to Fred’s point, the adapter seems to have a swivel that allows you to adjust the suction accordingly.
It looks like Home Depot sells a 1 1/2” upgraded hose for my vac that should work well. I’ll try that. Thanks!
View DirtyMike's profile
DirtyMike
637 posts in 956 days
#4 posted 01-19-2017 07:52 PM
How awesome is that sander though?
View Woodchuck2010's profile
Woodchuck2010
707 posts in 912 days
#5 posted 01-20-2017 01:27 AM
This hose works great with my Bosch.
http://www.rockler.com/dust-right-universal-small-port-hose-kit-with-auxiliary-hose
-- Chuck, Michigan,
View patcollins's profile
patcollins
1687 posts in 2919 days
#6 posted 01-20-2017 01:31 AM
Duct tape, always duct tape.
View RobS888's profile
RobS888
2457 posts in 1899 days
#7 posted 01-20-2017 02:25 AM
- Woodchuck2010
I have to second this one and the duck tape as well!
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
