Finish & Glass
Forum topic by FaTToaD posted 09-02-2010 07:55 PM 894 views 0 times favorited 2 replies Add to Favorites Watch
View FaTToaD's profile
FaTToaD
394 posts in 3105 days
09-02-2010 07:55 PM
Topic tags/keywords: box glass tape tip finish question wine
I’ve got a question regarding glass in woodworking projects.
I’ve been asked to make several more wine cork display cases for friends and coworkers, and each has a piece of 1/8” glass seated in a small dado in each side. The first couple I made, I just taped the glass with blue painters tape the best I could, finished it with danish oil or wipe-on poly, removed the tape, and scrapped what finish had dried on the glass with a razor blade. This worked out ok, but I was very time consuming.
Is there any better ways to handle this? I can only get the painters tape so close to the edge, and a little finish always dries and has be to removed from the glass. Any LJ’s out there with experience finishing around glass that may have some tips?
I thought of prefinishing the sides, but everyone loves those miter splines and so that’s out of the question.
Thanks in advance!
-- David
2 replies so far
View lew's profile
lew
12017 posts in 3719 days
#1 posted 09-02-2010 08:15 PM
Maybe replace the dado with a rabbet and quarter round trim piece. Do all the finishing and then install the glass. This would also permit replacing the glass if it were to get broken.
Lew
View nailbanger2's profile
nailbanger2
1041 posts in 3107 days
#2 posted 09-02-2010 09:17 PM
I like lew’s idea also, but if you don’t, maybe you have enough room between glass and wood for playing cards? or wax paper, though stiffer is easier.
-- Wish I were Norm's Nephew
