Forum topic by helluvawreck | posted 09-02-2010 06:22 PM | 3584 views | 1 time favorited | 11 replies | ![]() |
Topic tags/keywords: dovetails first pins first dovetails pins dovetail last pins last dovetail pin joining I did a search on this on LJ and for three pages a specific thread didn’t show up so I thought I would just ask. Which do you cut first, dovetails or pins, and why? I cut the tails first because it just seems more natural to me and it is easier to position the tails over the other part to mark the pins. In the literature I’ve seen that the preference runs either way. You don’t have to go into any great detail unless you just want to. It’s just sort of an informal survey to see how it runs on Lumberjocks. -- helluvawreck aka Charles, http://woodworkingexpo.wordpress.com |
11 replies so far
#1 posted 09-02-2010 06:33 PM |
http://woodtreks.com/how-to-hand-cut-precision-dovetails-%E2%80%94-part-one-the-pins/75/ This is a link to a great little video series. This shows cutting pins first. I think you will get about a 50/50 split on which to cut first. I cut pins first. -- Lew- Time traveler. Purveyor of the Universe's finest custom rolling pins. |
#2 posted 09-02-2010 07:04 PM |
I cut tails first but I don’t know that it really matters. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#3 posted 09-02-2010 07:09 PM |
My first dovetails will be for the fronts of these nightstand drawers. I’ve thought about it and I hear its a little easier to start with tails first so I probably will. -- - Eric Noblesville, IN |
#4 posted 09-02-2010 07:18 PM |
Pins first because Tage Frid said so :-). Seriously, no particular reason why. I’ll try tails first next time. |
#5 posted 09-02-2010 07:22 PM |
Like Lew says its a 50/50 thing. Its more of just a personal preference than anything. Cutting tails first for most is a visual thing as can be said for pins as well. I will say for myself its a matter of figuring the spacing for the tails mostly. -- I don't make mistakes, I have great learning lessons, Greg |
#6 posted 09-02-2010 08:00 PM |
I had always cut tails first, until i went to school and learned. -- Junior -Quality is never an accident-it is the reward for the effort involved. |
#7 posted 09-02-2010 08:50 PM |
JuniorJoiner makes a very good point. Consider me converted. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#8 posted 09-03-2010 05:36 AM |
Isn’t that the woodworking equivalent to the chicken or the egg question. Personally, I kind of agree with the way I have always seen Roy Underhill do it. He cuts the kerf for the tails first and then uses the kerf to mark the tail board by pulling his dovetail saw through that kerf. This leaves a nice mark to assist in getting the saw started on the exact line needed for the pins. This would not be possible if you were to cut the pins first. If done correctly and then carefully cut, the joint has to fit together. -- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc |
#9 posted 09-03-2010 05:55 PM |
I appreciate the response, fellas. Like some of you said, it’s probably a 50-50 thing. I think it’s probably going to hinge on what feels like the most natural way to do it to each person. -- helluvawreck aka Charles, http://woodworkingexpo.wordpress.com |
#10 posted 09-03-2010 06:16 PM |
I’ve found tails first to work better for me in through and 1/2 blind dovetails. There is no need to slant a board when sawing the tails. If your saw is “tuned up” it is just as easy to saw at an angle as to saw vertically. Less screwing around with the material. For me, transferring the marks is easier too because I’m not trying to balance a narrow board on end. Sure, you can make little right angle jigs and fool with cabinet clamps and what not. But why add more gizmos? Clamp the future pin board in the face vice at the same height as your smoothing plane lying on its side, slide the plane back to support the far end of your tail board. Hold the tail board in place with one hand and knife the marks with the other. Or skip the knife and use your saw slid though the tail kerfs prior to chopping out the waste (tried it, like the knife better). And for what its worth, I use a double bevel marking knife so I don’t have to worry about scribing to the left or the right of a reference edge. D.B. knives worth from either side. Single bevel knives not so much. Xacto and pen knife blades work too but you have to remember to square up against the bevel, not the flat side of those blades. -- Don't sweat the petty things and don't pet the sweaty things. |
#11 posted 09-03-2010 06:22 PM |
Several years ago, I learned to cut the tails first and I have stuck with that. I recently took a workshop with Steve Latta and he cut the tails first. It made me a little dizzy just because it was different. I have no real argument for doing it that way. -- “Big man, pig man, ha ha, charade you are.” ― R. Waters |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2102 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4899 |
6689 |
28034 |
CNC Woodworking
211 |
Hand Tools
5403 |
Jigs & Fixtures
1417 |
Wood & Lumber
6223 |
1387 |
Focus on the Workspace
2152 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2197 |
Coffee Lounge
8842 |
