I have a plane that was given to me years ago. When I took it to a old wood boat builder, who I use to pester the H out of, when getting new to me hand tools. Since He knew tools inside out and backwards. He told me. It was a Bailey definite. If it is I don't know. He showed me 3 he had. He was 85 then and told me he kept them for his boys to use, they were 65 and 68. And he still wouldn't let them use his personal planes. But that isn't the reason for this post, the plane its self is. He told me they were a cheaper plane Bailey made. They sold, back when Bailey made them, for around $3. Now to why this post, it has a stamped metal frog. Now some think this makes a plane a cheap plane that you should just throw away. Well I learned on that day, it may not sell for much but it can be made to work great. So I thought I would share the info. That old timer showed me. First he told me to adjust it. Then make a cut. Well I tried. He then told me to take a good look at the plane. We found chips in between the chip breaker and the iron. Also I saw the iron bevel was up and their was a space between the back side of the iron and the mouth. So we then took it apart and went to work on it. First we filled the radius off from the vertical rib, between the frog mounting surface. Then flattened the mounting face for the frog. Both need that. We then flattened the frog mounting flanges them self's. Next we flattened the iron and chip bracker mounting face of the frog. We then adjusted the the space between the frog mounting flanges. After taking the chip bracker and iron apart. Cleaned the iron and made just a few passes of the bevel on his hard oil stone. Then ran the chip bracker mating surface on the chip bracker to flatten it. After all of this, we put it back together, adjusted the frog so the iron set on the bevel in the mouth. We then adjust the iron to make a cut. Made a few passes to where it need to be to cut. Well did that plane cut. He told me to run the iron once in a while on my hard oil stone to keep it cut, and it will serve me me well for a long time. Well that was 40 years ago and that plane is still used by me and still cuts just as good as my Stanley #4, and I should mention its the same size as the #3. Now any one that has a plane with a stamped frog and is ashamed to tell anyone. Or you can't afford a plan in a size you would like to have and found a plane with a stamped frog. Don't be afraid to buy it and use it, after you do some work on it. I know their will be some that will disagree with me, and that's OK. Because I'm old and don't care. That's the way us old farts are. The biggest thing you find out about getting old, is you can say things you couldn't get away with when you were young.
It's very hard to tell from your post, but are you trying to say that the plane with the stamped steel frog is a Stanley?
If so, I have to tell you, I know of no such Stanley plane.
Aside from the Stanley/Bailey planes, there have been several low to lower-end Stanley lines over the decades, (Handyman, Defiance, Four Square, etc.) but those that did not have true, separate cast iron frogs, had vestigial cast pedestals.
Now where to start. No I didn't say it was a Stanley. What I said, and I thought it was clear,
" he told me it was a Bailey Definite. If it is I don't Know. He had 3." I also said " he told me they were a cheaper planes built by Bailey."
now you said they made a defiance, OK I'm no expert on old plane names, and don't want to be, but I do know the plane makers from those days, made a number of planes for some companies with no names or that companies name. Also I said
"Now to why this post"
Then I went on to say these are cheap planes. But you can make them work well. I then explained how he showed me what I needed to do. I also said this was 40 years ago. I don't know about you, but I'm old and can't remember what I did yesterday let alone 40 years ago.
The problem I have had over the many years of my life and with every hobby I've ever been involved with, is people that can afford higher end items, giving the impression to young people and to those that can't afford the higher end stuff. They are made to feel that what they have won't work. This is ever so true in another hobby of mine, which is fly fishing. Their are so many people that make young people feel their not true fly fishers, unless they buy only high end equipment.
I taught fly fishing for 45 years and have been fly fishing for 60. So I dislike people that make others feel Their really not part of the sport. I have made a number of the high enders look bad, by out casting them and out fishing them with so called cheap equipment.
I was really hoping to just talk tools here on this site. But since I'm still learning to navigate here. I really didn't want to get into a spiting contest over semantics. But was hoping to just let those who have cheap planes know how to tune them to make them a good usable tool. I know for a fact, that there are a few young people out there, that have not signed up here or on other sites, for that very reason. I joined here after talking to one at the local wood shop I use. He told me about reading things here that has help him. I ask does he post. He said "no, I'm not in their class." Now is that what people want? Or do people want to help others? I really don't care what the name of the plane I have is. But I know it works really good and I still use it.
Now for pictures. Man I love picture more then most. But since I'm still learning how to do things here, I haven't learned how to post pictures yet. But when I do, you can be sure I will post them.
Now I have to go take a nap. I haven't though about or typed so much in a long time. Now my brain hurts from thinking to much. You see I still have one hell of a sense of humor.
Saltfly, talk away man! There are a bunch of folks interested in talking tools here, we do it quite a bit. It's not a semantics things, really, when folks wonder what kind of plane it is you've made to work so well… the Stanley / Bailey lines of planes are well-documented, so people want to apply that learning to what you're saying. And there isn't an example I've heard of where Bailey -or Stanley- made a steel-frogged bench plane. Stanley did make steel planes, notably the S4, S5 and S18, be even those bench planes had iron frogs; the S18 is a block plane, of course (no frog).
If you've got a smartphone, posting pics is very easy and you'll be able to learn quickly. Hope to see your plane soon!
Better watch out, there are some here who will follow you around…..or just "block" you….DAMHIKT….LOL.
The biggest problem I found with the steel frogs? Is where the bolt for the lever cap screws into the frog…..bolts will go in, a bit too loosely, and then allow other parts to move when you rather they did not. It almost looks like a steel insert had been installed in the frog, to allow the bolt to be used. The insert itself tends to wiggle a bit.
Flatten the soles, sharpen the irons, and they can be made to work. Have had many of them come through my shop over the years. Frog can be removed, it's face flattened for a better mate to the iron….but is a royal PITA to get the frog installed back on the base. A magnetic tipped screwdriver is a must.
Had one come through, not long ago..
And another, this one was sold as a "Worth" brand by PEXTO. Did fairly well on Sycamore…..
Smitty you sound like my kind of guy. No me and smart phones don't see eye to eye. (My wife gives me what for, because I run my boat 30 miles off shore and she can't get me when out their. that's the point theirs no cell towers out there and I can be left alone to just fish). I do get on other sites, a few boat restoring sites and fishing sites. What I do there is put photos from my camera into photo bucket and then copy them to my posts. Don't know if that will work here but I will try.
Bandit I'm an old Airborne Ranger, spent 3 years in southeast Asia with a Sp Ops detachment 1966 threw 1969, and still teach Martial Arts. I learned when to fight and when to run. Right now, I don't see a reason to run. But thank you for the heads up. I know their will always be a few. "Wink"
And johnny7 please don't take what I said personal, but you came across a little strong in your comments.
Also I noticed a number of vets here some use their unit patches, 101st airborne and a SF patch as well as a master Sargent, I'm sure there are many others. So thank you all for your service.
Your argument for cheap planes is a common one here. You'll find thread after thread about what's needed. Part of the problem lately has been the attitude that it matters.
My philosophy is if you can buy expensive tools and can afford expensive tools then buy expensive tools, but agree wholeheartedly almost any plane cane be made to work.
Most of us agree with your philosophy, but it tends to start disagreements.
And it's OK if you don't care what brand of plane you have, but being a bit of a tool history nut, when I hear of a plane I haven't seen before (like a steel frogged Bailey) I start to ask questions. Its out of pure interest, not disrespect.
Well I got some pics uploaded. So here are a few of the plane I was talking about. I was given this plane around the end 1971 or the beginning of 1972. Right after I got my discharge from the army. My friend thought wood working would help me settle back to a more normal life. Hell its now 45 years later and I'm still trying to figure out what a normal life is. Theirs nothing normal about this world today.
Next to my #4 http://i782.photobucket.com/albums/yy102/saltfly/wood%20working/DSCN0881_zpsa65mtfk3.jpg[/IMG][/URL[/URL]]
I'm sure that my opinion/advice to another member about Stamped steel frogs is what triggered 'saltfly' to start this discussion. Hey, if you got one and it works for you, all's well. I won't use them, except for parts.
Well poopiekat the post your are talking about had nothing to do with my post. I didn't read that thread. Sorry if you think I started this thread because of your post. I'm new here and just want to start a thread about a plane I had restored. I thought I could get to know some of the people here. I had no intention of stepping on any toes. Wood working is a basic hobby. Their are a number of sub hobbies in it. Hand tools, power tools. hand planes etc etc etc. I found out on here it is very easy to be miss under stood when talking about some thing that bleeds over into other sub hobbies. but its no big deal. I was just trying to post some pictures because some asked to see some. But as you can see, I'm having a few problems getting them to show up.
You guys have got me wondering now as well. It was 40 years ago, when I was told what he said it was. I wouldn't have known the difference then as well as now. And the true is I didn't care then it worked well for me then and still does.
Saltfly, I picked up a Pexto with stamped frog looking similar to your plane. Hope it cleans up and works as well as yours.
I just want to add that there are a lot of us here and on oher forums that can't afford Cadillacs, much less Ferarris. We drive pre-owned Fords and Chevs - even a few Yugos. The same with our tools. We make do with what we can afford - and we get 'er done anyway. We learn to succeed despite the obstacles - just like your Spec Ops training. Congratulations and keep hanging around.
bridgerberdel sorry for not responding, but I don't get on this site much. no use to, get ignored most times. No their are no markings any were on this plane. But it cuts good. I picked up a #3 stanley which I now use more. But I still get it out once in a while and use it.
Looks like you did a fine job getting it up to working speed, whatever it is. And you're not ignored. Many, many lurkers here that don't post. You get used to it.
Well I pick up two project planes. One a Stanley defiance the other a Craftsman made by it looks to be Sargent. $9 ea. Not to bad a price. Both are #4 sizes. I checked them out on Dons site. To see who made them. And they match those two planes. They need a good cleaning and sharpening. The craftsman iron was sharpened as a scrub, but the radius was way to small for a 2" iron. Looks to be only a 3" radius. I sure it never work, because the mouth of the plane was closed off with the iron. I'll have to grind that way back. Fortunately it has plenty of meat left to work with. I'll post some pictures of before and after once I get to them. Witch shouldn't be to long, since the weather around here is going to be bad for the next week. So I'll be working in the garage instead of on it like I would rather be doing. Need to get my wood shop back.
Well I still haven't had time to cleaned these two plane nor restored them. But I thought I would post their pictures as is, because it looks like it will be a while before I get to them. If you look at the one I think is a defiance, you will see the v shaped lateral adjuster, as well as the tell tail red ear tote. After check time tested tools quick check for plane ID. This one is a #4.
This is a, I think a Sargent made Craftsman for the same reason above. I checked time test tool to ID it. If you look at the frog it looks just like the one on don site. What was interesting was the guy who owned it try to change it to a plow plane. And it was never going to work. The mouth on this plane is just to tight. If you adjust the iron out just a 1/16 of an inch. You close off the mouth and you only have about Âľ of a inch of iron to work with. So I will square it back up. This one is wider then a 4 but I think it is still a 4.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
