Wiring question for my 8" Grizzly Model G1018 Jointer
Forum topic by kkm0005 posted 01-18-2017 06:52 PM 1962 views 0 times favorited 11 replies Add to Favorites Watch
View kkm0005's profile
kkm0005
5 posts in 692 days
01-18-2017 06:52 PM
Hello all,
I have recently purchased an 8” Model G1018 Jointer from craigslist and looking forward to using it. However I have a few concerns.
The jointer is wired for 220V as i expected it would be. As i do not currently have an outlet for that yet, I am in the process of adding one.
Here is where my issue begins. All of the paperwork/manual for this jointer says the the plug should be either the NEMA 6-15 or the NEMA L6-15. But the current plug on the jointer is a NEMA L6-30. I am assuming that previous owner changed that. My question is, should I change it back?
I would rather have the NEMA -15 because that’s what the paperwork says it should have.
ANY help would be greatly appreciated.
thanks
kevin
11 replies so far
View unbob's profile
unbob
810 posts in 2100 days
#1 posted 01-18-2017 07:07 PM
I cant even guess how many styles of 220 single phase plugs there are, but the types go with the amp draw of the machine.
I have the same machine, being 1 1/2hp, any style should work fine.
View MrUnix's profile
MrUnix
7036 posts in 2395 days
#2 posted 01-18-2017 07:09 PM
Manual only claims it needs a 10A circuit (motor rated at 9A@120V), so your regular household outlets should be sufficient (15A). I’d just wire it for 120V, put a normal 5-15 on there, and call it a day. The 6-15 is for 240V (and the prong configuration is identical to a 6-30, so what would be the point in swapping it?).
PS: The manual also states that the machine did not come with a plug as shipped from the factory – it’s up to you to put a plug on it to match your outlet.
kkm0005
5 posts in 692 days
#3 posted 01-18-2017 07:10 PM
Unbob,
What I’m wondering that the plug currently on the machine is a 30A plug. When the plug that came with the machine is a 15A plug. Does that make any kind of difference?
MrUnix
#4 posted 01-18-2017 07:16 PM
Dang… I was looking at the wrong section in the manual… for 120V operation, it needs a 20A circuit. That 9A is for 240V. Never mind :)
(who needs a bit more coffee)
kkm0005
5 posts in 692 days
#5 posted 01-18-2017 07:18 PM
Thanks guys, I think through a little research I’ve answered my own question.
I appreciate the help!
View WhyMe's profile
WhyMe
1070 posts in 1757 days
#6 posted 01-18-2017 07:55 PM
- MrUnix
The 6-15 and 6-30 are not the same and are not interchangeable. The 6-15 is smaller diameter than the 6-30.
View bigJohninvegas's profile
bigJohninvegas
515 posts in 1658 days
#7 posted 01-18-2017 07:59 PM
My grizzly band saw came pre wired for 220v. And the instructions were the same as yours, but it did not come with the plug. I had to buy my own. You can put the nema 15 on it no problem. I would bet the original owner had a 30 amp circuit and put that plug on to match the existing outlet.
-- John
MrUnix
#8 posted 01-18-2017 08:01 PM
- WhyMe
Yeah, I realize that most of what I wrote was wrong… I had just woke up and was still on my first cup of coffee!
I need to refrain from typing until at least my second cup of coffee and morning dump :)
As I mentioned above, and in my best Emily Litella voice, “never mind”.
View William Shelley's profile
William Shelley
595 posts in 1666 days
#9 posted 01-18-2017 08:02 PM
L6-30 is incredibly common. I would just leave it and install the appropriate receptacle.
-- Woodworking from an engineer's perspective
runswithscissors
2890 posts in 2221 days
#10 posted 01-19-2017 05:56 AM
Plugs are cheaper and easier to install than receptacles.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3110 days
#11 posted 01-19-2017 02:31 PM
Pick and choose the 240v plug and receptacle of you choice, just make sure they match each other.
Plus, I prefer the twist lock type so you never get a “partial-plugged-in” machine. IMO safer.
