What to do with large boards on jointer and planer
Forum topic by yellowjacket posted 01-18-2017 03:24 PM 637 views 0 times favorited 4 replies Add to Favorites Watch
View yellowjacket's profile
yellowjacket
1 post in 642 days
01-18-2017 03:24 PM
Topic tags/keywords: jointer planer power tools tip trick plane
Hey guys, I’m new to the woodworking world, and already built a 7 FT trestle table with 4×4s and 2×12s… though it was a bit twisted and uneven due to not having a planer and jointer.. my question is, what should I do to support the 8’ boards that I want to send through the jointer and planer? I don’t have a big budget to get a jointer and planer, any suggestions? I have about 5-600$ and would like to keep it in the 500$ range. Appreciate any advice.
View builtinbkyn's profile
builtinbkyn
2636 posts in 1089 days
#1 posted 01-18-2017 05:59 PM
You can build a sled for your planer. For both the jointer and planer, you’ll need in feed and out feed support. You’ll also need a lot of room fore and aft of both machines for such long boards :)
Planer sled
Edit: Guess I should have read your post more carefully. No jointer or planer. Well maybe a visit to a local shop to see if they’d do it for you. You could also use a router to flatten the boards. That too will requite a jig.
-- Bill, Yo!......in Brooklyn & Steel City :)
builtinbkyn
#2 posted 01-18-2017 06:03 PM
I should have read your post more carefully. No planer or jointer. Maybe a local shop can do this for you or you can use a router. Router planer sled.
View rwe2156's profile
rwe2156
3094 posts in 1629 days
#3 posted 01-18-2017 06:40 PM
Roller stands.
MrUnix
6948 posts in 2347 days
#4 posted 01-18-2017 06:41 PM
You are going to have to explain what it is you are trying to do a little better… you want to know what is needed to send long boards through a jointer and planer, but you don’t have a jointer or planer?
