Help fixing cast iron blade drive on table saw
Forum topic by Hoowaa posted 01-18-2017 03:52 AM 848 views 0 times favorited 9 replies Add to Favorites Watch
View Hoowaa's profile
18 posts in 847 days
01-18-2017 03:52 AM
Topic tags/keywords: cast iron table saw metal crack jb weld repair fix
I recently discovered the main trunion (cast iron part that holds saw motor) on my table saw broke.
Any recommendations on how to repair. I don’t weld and unfortunately, buying a new saw is not an option right now. I either have to fix this one or do without for the next 12 months or so.
I was thinking of re-attaching with JB Weld and then lashing the two parts with wire or metal (as indicated by the red lines on the last two pictures).
9 replies so far
View RogR's profile
109 posts in 797 days
#1 posted 01-18-2017 04:40 AM
Have you tried sourcing the replacement part? If not new, then used? If you have access to a torch, you might try Castaloy, but alignment could be critical.
6480 posts in 2131 days
#2 posted 01-18-2017 04:40 AM
I seriously doubt that JBWeld would hold up, even if you strapped it like you are thinking… You could probably find a local welding shop that will braze it for you cheap, or just buy a new part (searspartsdirect or ereplacementparts both appear to have them available).
#3 posted 01-18-2017 05:16 AM
Thanks for both suggestions. When the part number wasn’t recognized on the sears webpage I thought I was out of luck. I just placed my order on ereplacementparts.
View splintergroup's profile
1934 posts in 1155 days
#4 posted 01-18-2017 03:38 PM
I agree, just replace it. Welding cast iron properly is a black art and then the alignment will be forever tweaked.
eReplacement parts is a great place, though rather expensive. Do an exhaustive search first, you might save a few bucks.
View CC68's profile
8 posts in 1953 days
#5 posted 01-20-2017 03:37 AM
wow that sucks!!!!!!! this is what i would do i would contacted the company wow made it and see if it has a recall on it. that should not of broke there is not enough torch on that to break it like that! good luck!!
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3645 days
#6 posted 02-19-2017 01:03 AM
How did the replacement go?
View corelz125's profile
361 posts in 908 days
#7 posted 02-19-2017 03:42 AM
I have the same saw and had the same problem. just that when i took it out of the box it was broke so it was covered under the warranty just had to wait weeks for the part to come from china.
#8 posted 05-16-2017 03:56 AM
I finally had some time to replace the part. Everything appears to be working properly. Thanks for all the tips and suggestions.
#9 posted 05-17-2017 12:41 AM
is your belt good and tight on it now?
