Am I using wrong product? Or doing it wrong.
Forum topic by Steven H posted 09-02-2010 02:59 AM 1277 views 0 times favorited 14 replies Add to Favorites Watch
View Steven H's profile
Steven H
1117 posts in 2931 days
09-02-2010 02:59 AM
I want a glossy shiny finish on my push stick, so went to buy Varathane
Diamond Polyurethane (spray can version). Clear Gloss
The wood is stained with minwax.
So I sprayed 4 times.An 30 minture dry between recoat. Before final coat sand with 220.
I notice some part of wood is glossy and some aren’t.
14 replies so far
View lew's profile
lew
11890 posts in 3626 days
#1 posted 09-02-2010 03:50 AM
Spraying with clear coatings can be “misleading” because it’s hard to see where the coverage is sufficient. Maybe, after sanding, you missed a few spots.
Just my 2ยข
13594 posts in 3212 days
#2 posted 09-02-2010 03:56 AM
more coats more sanding
spray cans can be thin coats
View vicrider's profile
vicrider
179 posts in 2769 days
#3 posted 09-02-2010 04:30 AM
i always suggest a seal coat of Shellac prior to applying any ‘film building’ finish. It sounds as if you are not getting a consistent absorption of your gloss finish.
-- vicrider
Steven H
#4 posted 09-02-2010 05:22 AM
This is my first time using water base Polyurethane
please bear with me
I notice the grain on the wood is the only part is shiny. Similiar like this.
Is it because the wood im finishing causing this?
It is pine that I’m using.
View Bearpie's profile
Bearpie
2601 posts in 2889 days
#5 posted 09-02-2010 06:12 AM
You are getting absorption into the soft parts of the wood and maybe a couple more coats will do it! Pine is notorious for absorption into soft parts before it is finally saturated enough to finally stay on the surface.
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
Rick Dennington
5656 posts in 3065 days
#6 posted 09-02-2010 07:07 AM
Greetings StevenH,
This may sound like a dumb question, but why do you need a shiny push stick? It’s just a push stick…. a tool…...not a piece of furniture that requires a glossy finish…...you’re gonna get it dirty the more you use it I make mine out of plywood, smooth them down, and now they are dirty brown from using them…...
-- " Don't pet the sweaty things, and don't sweat the petty things."
View Manitario's profile
Manitario
2581 posts in 2754 days
#7 posted 09-02-2010 08:32 AM
My own brief experience with Diamond polyurethane I sanded with 220 between each coat, and used 4 coats total. I had to put a heavier first couple of coats on. Granted though, I brushed it on rather than spray it…
View grosa's profile
grosa
1002 posts in 2700 days
#8 posted 09-03-2010 06:43 AM
You need some more coats of finish. Sand with 220 between coats and build it up. Pine sucks it up like a straw. You should use a sealer on soft woods.
-- Have a great day.
View Rick's profile
Rick
8538 posts in 2903 days
#9 posted 09-04-2010 02:59 AM
I do the same thing basically as vicrider suggested, especially for pine. One difference. Long time ago a Painter taught me to mix White Shellac with Methyl Hydrate about 50/50 as a Sealer. It dries Really Quickly and you can do a couple of coats in a half hour or so. Seals Nicely.
Methyl Hydrate is also used as “Fondue Fuel”, they add a lilltle color to it and charge you $$$$$’s for it. Right out of a $3.00 Plastic Container sold in the Paint Department is just as good. There’s probably other uses for it also. That stuff Burns MEGA HOT!
Rick
-- A Chip On The Shoulder Usually Indicates Wood Higher Up. (Rick, Ontario, Canada)
View Dark_Lightning's profile
Dark_Lightning
3020 posts in 2979 days
#10 posted 09-04-2010 03:11 AM
Methyl Hydrate is also known as methanol (methyl alcohol). Personally, I’d put the shellac on straight. One coat instead of two thinned coats. Just don’t put it in your grape juice, it’ll make you go blind.
And, yes it appears that the summer wood is really sucking up the finish. That’s typical.
-- Random Orbital Nailer
View William's profile
William
9949 posts in 2713 days
#11 posted 09-04-2010 03:18 AM
In my opinion, pine is one of the worst woods to finish. The softer spots absorbs finish like a sponge while other parts take it quite well. It can make a beautifully interesting wood grain when using dark stains, not so great with clear finishes. Several suggestions have already been made for seal coat. If I’m just putting clear finish on pine though, I seal it first with Minwax sanding sealer.
View TheOldTimer's profile
TheOldTimer
226 posts in 2957 days
#12 posted 09-04-2010 03:58 AM
As stated above, two coats of de-waxed shellac. I do not sand the shellac I sand the first top coat with 320 grit paper then sand between coats with 400.
-- TheOldTimer,Chandler Arizona
View bob101's profile
bob101
321 posts in 3321 days
#13 posted 09-06-2010 03:54 AM
dont waste the time on something your going to end up getting kerf cuts on anyway, i go threw push sticks like crazy, (plywood). maybe thats just me though!
-- rob, ont,canada
View rance's profile
rance
4255 posts in 3031 days
#14 posted 09-06-2010 04:08 AM
Finish, or no finish, it’s up to you. Nothing wrong with wierd tools. I finish some of my jigs too. But you DON’T want to finish the bottom of your push stick, it needs to grip the wood as best as possible. :)
