Board Foot Calculation
Forum topic by JKVWood posted 01-17-2017 04:12 PM 757 views 0 times favorited 14 replies Add to Favorites Watch
View JKVWood's profile
JKVWood
4 posts in 641 days
01-17-2017 04:12 PM
Howdy.
I need help calculating this butcher block island. It’s going to be made with edge grain, 55” long, 54” wide, 1-1/4” thick. I know BF is LxWxH, but flipping the wood for edge grain is throwing me off. I’m just looking for an exact measurement, no need to count for waste, kerf, etc.
Thanks!
14 replies so far
View buckbuster31's profile
buckbuster31
243 posts in 424 days
#1 posted 01-17-2017 04:18 PM
should still be the same board feet I would think
View splintergroup's profile
splintergroup
1880 posts in 1130 days
#2 posted 01-17-2017 04:37 PM
BF is measured for rough cut. That is, a board described as 2bf would be 6” wide by 4 feet long by 1” thick.
If finished (planed) on both sides the thickness would be more like 7/8” or 3/4” so you need to adjust your order for that difference if it applies. If the board has straight cut sides, this makes the 6” wide rough board often as little as 5-1/2”
Butcher blocks have a lot of waste with the cuts and final flattening, getting close to 2x the actual wood volume in the final product.
View AlaskaGuy's profile
AlaskaGuy
3913 posts in 2217 days
#3 posted 01-17-2017 05:35 PM
You keep saying “edge” grain. Do you mean “end” grain?
View bondogaposis's profile (online now)
bondogaposis
4611 posts in 2259 days
#4 posted 01-17-2017 05:58 PM
25.8 bf.
-- Bondo Gaposis
View RogerM's profile
RogerM
790 posts in 2307 days
#5 posted 01-17-2017 07:49 PM
Board feet is a measurement of volume. I BF always equals 144 cubic inches. Therefore, Width (inches) X Length (incles) X thickness (inches) divided by 144 will give you board feet.
-- Roger M, Aiken, SC
View ScottM's profile
ScottM
597 posts in 2055 days
#6 posted 01-17-2017 08:46 PM
Try this site.
View William Shelley's profile
William Shelley
538 posts in 1377 days
#7 posted 01-17-2017 10:02 PM
An end-grain butcher block will probably have a LOT of waste. I’d factor in +20% to +40% to the actual volume.
-- Woodworking from an engineer's perspective
View MT_Stringer's profile
MT_Stringer
3154 posts in 3139 days
#8 posted 01-17-2017 10:10 PM
Howdy.
I need help calculating this butcher block island. It s going to be made with edge grain, 55” long, 54” wide, 1-1/4” thick. I know BF is LxWxH, but flipping the wood for edge grain is throwing me off. I m just looking for an exact measurement, no need to count for waste, kerf, etc.
Thanks!
- JKVWood
Got clamps? :-)
That is going to be a heck of a glue up. Good luck.
Assuming no loss for waste – 25.8bd ft. But there will be waste…quiet a bit for sure.
View JBrow's profile
JBrow
1326 posts in 828 days
#9 posted 01-18-2017 12:47 PM
JKVWood,
Board feet can be calculated by first defining a surface (that has width and length) whose area in square feet is calculated. The area of the surface is then multiplied by the thickness, in inches. Re-orienting the boards effect the surface for which the area is calculated as well as the thickness measurement. The calculated result should be the same no matter how the volume of wood is defined.
If length is 55 inches = 4.6 feet and width is 54 inches = 4.5 feet, the surface area is 4.6 feet X 4.5 feet = 20.7 square feet and board Feet is 20.7 square feet x 1.25 inches = 25.9 board feet
On the other hand if length is 55 inches = 4.6 feet and width is 1-1/4 inches = .1 feet, the surface area is 4.6 feet X .1 feet = .48 square feet and board feet is .48 square feet X 54 inches = 25.9 board feet.
ScottM
#10 posted 01-18-2017 12:51 PM
JKVWood,
- JBrow
Exactly what this site says it is….
View rwe2156's profile
rwe2156
2804 posts in 1389 days
#11 posted 01-18-2017 03:49 PM
Board feet is a volume measurement to it doesn’t matter.
The number Bondo gave is correct.
Best to always go 10-20% over to allow for imperfections in wood and the “oops” factor.
View RandyinFlorida's profile
RandyinFlorida
229 posts in 1976 days
#12 posted 01-19-2017 03:26 PM
For what it’s worth my downloaded APP says 24.7 BF. Several different apps available at the APP store.
-- Randy in Crestview Florida, Wood Rocks!
View GR8HUNTER's profile
GR8HUNTER
3304 posts in 620 days
#13 posted 01-19-2017 04:35 PM
Try this site.
- ScottM
DITTO ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View JayT's profile
JayT
5524 posts in 2119 days
#14 posted 01-19-2017 04:48 PM
There’s a different issue here that splintergroup touched on, but I don’t see where it’s been factored into any of the calculations. While board feed is a volume calculation and should not change, the reality is that it’s not a true measurement, because nominal 4/4 stock is only ~3/4in thick once planed, but calculated as if it is 1in thick.
So what I see is that while the shape that is being built is 24.8 bd ft in volume, turning the pieces on edge means that it would take 72 sticks that are 3/4in thick to get the 54in desired width. Running the calculation with that many pieces means that 34.375 bd feet of 4/4 stock will be needed to complete the project, plus waste.
If the final thickness of the planed nominal 4/4 stock is 7/8in, then it would take 29.6 bd ft of stock, plus waste.
I think that is what the OP was referring to when he said the edge grain aspect was throwing him off.
