Router Table Insert Cutout: Rabbet or Straight w/ levelers?
Forum topic by Alan S posted 09-01-2010 05:42 PM 3025 views 0 times favorited 5 replies Add to Favorites Watch
View Alan S's profile
Alan S
181 posts in 3554 days
09-01-2010 05:42 PM
Up until recently, I thought the only way to cut for a router table insert was by making a rabbeted shelf that the insert sits on. The depth of the rabbet had to be exactly the thickness of your router plate. Recently, I saw someone route out a straight-through hole the exact dimensions of the insert. They then attached some levelers to the bottom of the table that stuck up through the cutout and could be adjusted to correctly position the insert vertically.
How have you guys made your router tables? Do these levelers work and hold up over time? Thanks!
Alan
5 replies so far
View rance's profile
rance
4267 posts in 3397 days
#1 posted 09-01-2010 05:51 PM
Yes, very well. Leave a gap in the very corner behind your levelers though so it can’t get filled up with sawdust.
View PurpLev's profile
PurpLev
8548 posts in 3885 days
#2 posted 09-01-2010 05:53 PM
if you can easily attach brackets under the table top and put levers – I think it’s a MUCH easier way about it.
I actually routed a rabbet on my table – because the material I was using was phenolic and I didn’t want to deal with gluing anything to it. however, I still routed the rabbet lower and AM using leveling feet to perfectly align the insert with the top of the table.
View richgreer's profile
richgreer
4541 posts in 3311 days
#3 posted 09-01-2010 05:56 PM
I’m with Alan. I have made a router table and I cut the insert with a rabbet. Recently, I was watching an episode of the WoodSmith Shop and they cut the insert straight through and used a lever system in the corners. When I make my next router top (if ever) that’s what I will do. It looks much easier.
Rick Dennington
6348 posts in 3431 days
#4 posted 09-01-2010 06:45 PM
Greetings Alan,
I’ve built about 4 router tables, and I’ve did it both ways. Lay the plate down on the top where you want to mount it,draw the outline of the plate, then move in about 1/2” all the way around, and cut a rabbit the depth of your plate. You can use a straight bit, or a spiral bit to get the cutout. But…. the easiest way I found is to lay your plate where you want it, draw the plate outline, and cut the hole all the way through… Then… make some 3/4x
3/4” cleats (2 short ones for the ends, 2 long ones for the sides), measure the thickness of the plate, and glue and screw the cleats in. Drill a hole in the corners of each cleat to fit your leveling screws (all router plates come with these), then when you put the plate in you can make the final adjustments for the plate to be level with the top…. piece of cake…. always more than one way to skin the old cat…...
-- " At my age, happy hour is a crap and a nap".....!!
View jussdandy's profile
jussdandy
157 posts in 3444 days
#5 posted 09-02-2010 01:26 AM
having done both and both work well, I really like the inserts, the ones im using now are kregs, they sell for about 15 bucks, I would use again.
-- Randy I have the right to remain silent, just not the ability ; )
