Confirmat Screws
Forum topic by Ntaskani posted 01-17-2017 02:47 AM 431 views 0 times favorited 3 replies Add to Favorites Watch
View Ntaskani's profile
Ntaskani
17 posts in 1245 days
01-17-2017 02:47 AM
To those of you who build cabinets, do you have a preference on what size Confirmat screws you use?
I was going to buy a bunch of them online through mcFeelys, but they come in 2 main sizes it seems: 7×50 mm and 5×40 mm.
Also, do you need a different drill bit for each size? They’re not cheap.
Should I stock up on both sizes or just stick with one size for most applications?
Thanks for any help!
3 replies so far
View waho6o9's profile
waho6o9
8238 posts in 2629 days
#1 posted 01-17-2017 02:56 AM
My understanding is confirmat screws are used with particle board or MDF.
I guess the 7×50 is for 3/4” stock and if that’s what you use I’d go for the 7×50
with the matching drill bit accessory.
HTH
View AlaskaGuy's profile
AlaskaGuy
4252 posts in 2361 days
#2 posted 01-17-2017 09:10 AM
I guess the 7×50 is for 3/4” stock and if that s what you use I d go for the 7×50
HTH
- waho6o9
What he said. You could use them in plywood but no need when assembly screws are cheaper.
View Loren's profile
10476 posts in 3700 days
#3 posted 01-17-2017 09:56 AM
You need very specific sizes of bits for different
materials with confirmats. Make some calls
if needed. My boring machine works for
confirmat holes in ply and MDF but that’s a
lucky setup… some setups could work with
ply but split MDF so better safe than sorry.
