Help! I'm warped!
Forum topic by glassyeyes posted 08-31-2010 11:24 PM 1186 views 0 times favorited 4 replies Add to Favorites Watch
View glassyeyes's profile
137 posts in 3261 days
08-31-2010 11:24 PM
Topic tags/keywords: oak white oak warp straighten cupped
I’m looking for suggestions for dealing with a large glued-up slab that has cupped across the narrow dimension. It is white oak, 26” wide by 72” long by 1 1/4” thick, made of three boards, with the ring pattern alternated (bark side up, bark side down, and bark side up). It bows 1/16th of an inch at the midpoint. I can’t plane it any thinner—the other table top has been constructed, and the two tables will be side-by-side.
1. Should I attempt to correct the bow before assembly, or depend on the casework beneath to straighten it out? (The frame is fairly heavy, and much of it is concealed. I plan on using pocket screws to mount the top.)
2. Is there a worthwhile method of clamping the wood for a while? Wet one side? Expose one side to the sun, to dry/shrink it?
Any suggestions would be appreciated; re-making this top is going to get expensive.
-- Now, where did I put those bandaids?
View ajosephg's profile
1880 posts in 3493 days
#1 posted 08-31-2010 11:47 PM
1/16” in 26 inches? If was me I wouldn’t sweat it – let the hardware pull it down. But I wouldn’t use pocket screws because they won’t let the top expand and contract, which will lead to a broken top or case.
Should use Table Top Fasteners that allow expansion, but still hold it together.
-- Joe
View levan's profile
472 posts in 2911 days
#2 posted 09-01-2010 01:07 AM
I agree with Joe 1/16’ should not be a problem. I think you could use screws if you slot the shank holes so the top can move.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
13598 posts in 3273 days
#3 posted 09-01-2010 01:13 AM
when you do screw it down ,
clamp a strong back to the top and the rails ,
that way the screws wont strip ,
as they are pulling it down one by one .
i agree , 1/16th isn’t a big deal .
#4 posted 09-01-2010 02:28 AM
Thanks, guys! The “legs” are actually flat panels, for a modern look; I was thinking about running something like a glue block along the inside edges of the base cabinet portion. I could then use levan’s idea of slotting the outside screw holes for movement and patron’s idea of strongbacks during assembly. I knew I could get some good advice on LumberJocks.
