Ideas for a small space take down bungee lathe
« back to Woodturning forum
Forum topic by Woodenfarmer posted 01-16-2017 01:55 PM 536 views 0 times favorited 3 replies Add to Favorites Watch
View Woodenfarmer's profile
Woodenfarmer
5 posts in 565 days
01-16-2017 01:55 PM
Topic tags/keywords: pole lathe bungee lathe no power tools traditional chisel handles tool restoration lathe turning
Hi everyone i beed a lathe to make tool handles such as xhisels and helper handles on old logging saws but i dont have room for a permanant lather and im not to safe with anything that spins fast i own a lot of hand tools like braces rip saws and am toying with the idea of a bungee powered lathe but heres a list of problems i need to solve and was wondering if any of you guys had any experince in this sector. So here goes
It needs to be small abd able to take down fkat i only have a 5ft by 10 ft space
I dont like the idea of the cord being on the work peice
I wouldnt like to have a massive foot plate
And i need as many rotations as possible to get a good finish.
Im not looking at doing bowls or anything like that as i said just tool handkes but it needs to be powerfull enough to be able to turn some pretty hard exotic woods
Thanks guys
Also this will be made from roofing timber off cuts i can get 2 by4 up to 2by 6
3 replies so far
View Woodknack's profile
Woodknack
12070 posts in 2435 days
#1 posted 01-16-2017 07:38 PM
Roy Underhill among others have built spring pole or bungee lathes for traveling and I assume they break down. Probably use tusk tenon construction.
Woodenfarmer
5 posts in 565 days
#2 posted 01-16-2017 07:40 PM
Thanks il take a look
View JayT's profile
JayT
5730 posts in 2266 days
#3 posted 01-16-2017 07:44 PM
Have you seen this blog post by Richard Maguire. Very simple to build lathe out of construction lumber. There is a link at the bottom of the article that takes you to the plans.
I built one of these over a year ago and used it for a few projects before getting a powered lathe late last year. Didn’t take long to build at all and worked just fine. I don’t know how you are going to avoid having the cord on the workpiece. The simple solution is to make the blank several inches longer than the final product so there is a place for the cord to run.
