| Forum topic by GaryK | posted 675 days ago | 9380 views | 122 times favorited | 90 replies | ![]() |
675 days ago |
Topic tags/keywords: jig planer router jointer If you don’t mine a little extra work, you can save money on lumber by buying it rough. This will sometimes get you a little extra wood. For example 8/4 surfaced lumber is 1 3/4” Anyway the problem is that most people don’t have a wide enough jointer to smooth I finally had my workbench clear of other projects so I thought I would share with you how I surface First you need a jig. I made mine 10’ so that I could do up to 9’ boards. Here is a closeup of the hook added to the end. -- Gary, East TX -- The longest journey begins with a single step. |
675 days ago |
Excellent Gary. It’s been on the back burner forever here. I’m glad you prodded me again. Bob -- A mind, like a home, is furnished by its owner |
675 days ago |
Really great instructions, Gary. Thanks for the tips. -- Thos. Angle |
675 days ago |
This is great, thanks Gary. -- Max "Desperado", Salt Lake City, UT |
675 days ago |
Great tips Gary. Nice job on the design and implementation. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
675 days ago |
Very good idea! I’ve done something similar, but without the wheels and carrier strips. You’ve definately taken this idea to the next level. -- http://www.north40custom.com -- http://north40studios.etsy.com -- |
675 days ago |
That’s perfect Gary. I’ve read about this, but didn’t know anyone that had tried it. cool. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
675 days ago |
This is brilliant. Very cool. |
675 days ago |
What a great strategy! -- Dorje (pronounced "door-jay"), Seattle, WA |
675 days ago |
That’s a heads up method for jointing and planing without multi-thousand dollar tools. Good blog. |
675 days ago |
Ingenuity is a good quality to have. This is a very well explained method of getting that first surface right. Thanks for the post. -- Working at Woodworking http://www.VillageLaneFurniture.com |
675 days ago |
Best version of this jig I have ever seen… Thanks! -- Chris |
675 days ago |
Thanks Gary, The step by step was great. -- Gene, a Christian in Virginia |
675 days ago |
Great tutorial Gary, along with a nice method of “jointing” a flat surface on a board. It looks like a great idea for those of use with a smaller jointer. -- Bill, Turlock California, http://www.brookswoodworks.com |
675 days ago |
Good work , Gary. Nice pictures, too! -- Sam |
675 days ago |
That’s a keeper. I’m going to borrow that one real soon. I usually crosscut near-to-size then work one side dead flat with hand planes then feed the rough side to the planer on a sled. Your jig handles long boards and can easily be adapted for shorter stock. Sweet! This one will be a major labor saver on the days I don’t have the time to push a plane. Nice job. always, -- "Imagination is more important than knowledge" -- Albert Einstein |
674 days ago |
Great way to recieve a good result Gary. Thanks for sharing. -- Grumpy - "Always look on the bright side of life"- Monty Python |
674 days ago |
Geeze . . . good work there G-man. Excellent pictures and text. Explained it very well indeed. -- The significant problems we face cannot be solved by the same level of thinking that created them |
674 days ago |
Gary, -- Jeff, Indiana |
674 days ago |
Thanks Gary, you have solved one of my problems. Excellent. -- Mike |
673 days ago |
Nice. I’ll trade you for my RAS. That’s a sweet jig. I’m definately building one of those. I like the idea of the runners in the grooves. -- Tony, Ohio |
673 days ago |
I wish I’d known about this sooner, I ripped 4 or 5 12 ft bds that were just too wide for my planer. The only other thing like this I’ve seen is one Mark DeCou used to flatten some wide boards. He had the same basic set up but just went back and forth to flatten his board. This is cool, no it’s way cool. mike -- Mike. mwurm13@yahoo.com |
673 days ago |
Not having a power jointer (I have been using hand planes), I will definitely use this tip. Thank You for posting it!! -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
673 days ago |
Good Job. -- Stevethepeeve -- I'm no rocket surgeon |
673 days ago |
SPalm – It should work great for cutting boards. I hadn’t thought of that. You could do many at the same time also. Easier to sharpen a router bit than planer blades after cutting endgrain. -- Gary, East TX -- The longest journey begins with a single step. |
673 days ago |
Wow, outta my league for now any way” That;s sweet I had a hazy dream once about a shop like yours!!!!! I’m still hearing it from the little lady about saw dust everywhere. . Some day O’ one of these days… All work now is still on site. Two thumbs up on this project it’s the thing us rookies drool over…... -- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ""BY HAMMER AND HAND ALL ARTS DO STAND""1785-1974 nyc Semper Fi, Patrick M |
672 days ago |
Another note. If you buy rough lumber, see if you could find someplace local to mill it for you. I have a place about 30 miles from me that will surface both sides for 7 1/2 cents a BF. That’s $7.50 So adding $.10 a BF for surfacing would still make it worth it to buy your lumber rough. -- Gary, East TX -- The longest journey begins with a single step. |
668 days ago |
This must be the top project yet, now that makes 14 projects to do, and I havent got all my equipment together yet. as I,m new to the lumberjocks. Expertly provided ! -- Keith, Chester, England |
655 days ago |
That’s a cool shortcut! :) Very informative… Thank you. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
620 days ago |
Gary, After your recommendation that I consider a planer over a jointer due to the typical budget and space limitations in my garage/workshop, I finally ordered/received my planer. I looked hard at the Delta and Dewalt 13” planers. Finally decided to go with the Dewalt because of the chip blower and three blades. I am about to begin flattening some boards, so I did a LJ search of came across your tutorial on this topic. Have to say LJ is a great resource for beginners. Sure helps with the learning curve. Thanks, Dalec |
620 days ago |
Nice. I’ve seen other versions of this jig which use angle iron for the rails, but I suspect your version yields a superior result. This is only my third post on this site; hopefully it doesn’t ostracize me. I’m not a militant handtool user. You could also do this with a handplane or two, which store very nicely :). I only have a 6” jointer (hoping to fix that “problem” soon), so I regularly surface wide boards with a jack and a jointer plane. Takes some skill, yes, but a skill that is very easily learned and pays off for a lifetime. |
620 days ago |
Narayan – I don’t use handtools unless it’s the best tool for the job. Seem too much like work :-) I only have a 6” jointer. That’s why I came up with this method, so I didn’t have to use my jointer at all. -- Gary, East TX -- The longest journey begins with a single step. |
620 days ago |
Great idea. I usually rip em all down to 6” so I can joint & plane. Thanks for the tip. -- Jason, AL |
620 days ago |
I have a piece of 6/4 cherry that’s a candidate for this jig. Thanks Gary Cheers -- A mind, like a home, is furnished by its owner |
620 days ago |
Another winner Gary! -- Bruce from Central New York |
620 days ago |
This method should show up in ShopNotes sometime soon. They have already sent me a check for it. -- Gary, East TX -- The longest journey begins with a single step. |
620 days ago |
Great idea and very clear instructions, Gary. But I have to say, I like the idea of paying a guy $7.50 per 100 bf to surface it for me even better! -- Charlie M. "Woodworking - patience = firewood" |
620 days ago |
Congratulations. This is a good technique and great explanation. Thanks for sharing. We can always say we saw it here first… -- A thing of beauty is a joy forever... |
620 days ago |
Charlie – I found out later that that’s with a $50 minimum. So you better have a lot of wood. -- Gary, East TX -- The longest journey begins with a single step. |
620 days ago |
You are right….that would be a lot of wood. If my math is right, though, $50 would get you 667 bf of surfacing. That seems like quite a bargain if you had that much wood. (Yes, Gary, I’m obsessed with avoiding any work I don’t find fun.) -- Charlie M. "Woodworking - patience = firewood" |
620 days ago |
wow great instruction. maybe when in have some time this summer I’ll try buying some rough lumber. thanks for the post. |
620 days ago |
Nice idea Gary. But as you have a planer, why do you just not use the sledge method to flatten one side of the board, then turn it over and thicken it in the normal way. This is the method I use for my 15” wide, 8/4 thick and 10’ long oak boards I used to make my table tops. Here is a link http://www.taunton.com/finewoodworking/FWNPDF/011175058.pdf, [Fine Woodworking #175] but I think you have to be a member I did use your described method once (without the wheels) to flatten a work bench – it worked a dream. I only ever buy rough lumber – it is a lot cheaper and you can get to use the full thickness especially useful when making curved parts for a project I.e. Chair legs, seat back rails. that 1/4” can make all the difference! -- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (http://www.poydatjatuolit.fi) |
618 days ago |
Another wiinner GK. I only have a 6 inch jointer (long bed Powermatic) but for boards over 6” it just can’t plane them flat and who can afftord an 8 or 10 inch jointer. (I always wondered why the price for a 8 is almost twice that of a 6 incher. I digress, this is a great idea for getting a truly flat milled wide board and I just might have that bottom cleaning bit hangin around by my Legacy Mill. Thanks for the great post. -- DocK, WV |
618 days ago |
Gary, I couldn’t help but notice. Is that a microfiche reader in your shop? -- Scott - Chico California http://chicowoodnut.home.comcast.net |
618 days ago |
ChicoWoodnut – Very observant. I had just bought a new lens for it and I took it down from the attic. -- Gary, East TX -- The longest journey begins with a single step. |
618 days ago |
Ah Yes Chico I see it now, Microfiche reader? You must collect 8-track tapes too. I think I’ve been chasing you two around this site all night. -- DocK, WV |
616 days ago |
Thanks for the great pictorial, a very handy setup. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
616 days ago |
Great idea Gary! That idea will allow us, with limited income, to expand our woodworking skills. Thanks. -- Ron in Osseo, Minnesota |
602 days ago |
Gary, Also, I do not have a jointer at all, so I think that in this case, the shorter the board you can use when you start, the less material will be wasted so cutting the lumber to the rough sizes first would probably be a good idea. Do you agree with this? |
602 days ago |
HokieMojo – you can frid the bit here: http://magnate.net/index.cfm?event=showProductGroup&theID=136 They have then all the way up to 2 3/4” It you use this method you don’t need a jointer. The length of the board doesn’t really matter unless it’s -- Gary, East TX -- The longest journey begins with a single step. |
602 days ago |
Very good idea. I was going to make one with just runners but I like the wheeled sled. I will also be borrowing this in the near future. -- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!" |
602 days ago |
I’ve had trouble with this before and didn’t know what to do about it. Now I do. THANX!!! -- Michael R. Harvey - Brewster, NY - RusticElementArt.com - SpaceAware.org - AnConn.com |
601 days ago |
After I read Tony’s entry I went and checked the link. I remember reading that at the time and thought that it was a lot of bother. Your jig is so much simpler. I just happen to have 4 wheels left over from when I took my old saw table apart. Lee -- No piece is cut too short. It was meant for a smaller project. |
601 days ago |
I love it, it has been added to the todo list -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
601 days ago |
Very nice. This may be a solution I can use. Thanks, Justin |
601 days ago |
Gary…..... ahhh ummm errr …...... Your good! Thanks for taking the time to post those pics. |
601 days ago |
Thanks Gary, another great idea! -- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17) † |
594 days ago |
very cool. I’ve seen that done other ways before, but not with routing the strips on one side. That seems to be the best melding of the techniques. I’m going to have to give it a try. |
558 days ago |
Thanks Gary I favourited it. -- Only the Shadow knows.................... |
558 days ago |
I made a similar set up to flatten out a 30” diameter by 12” thick Pine log for a display at a local museum. so they could show the growth rings. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
558 days ago |
Very cool jig Gary. Better than a sled, I can see how that this will take out slight cup in your lumber too with a planer only and very little work otherwise. Great idea -- Ed |
542 days ago |
This post is a keeper, thanks Gary. -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
529 days ago |
Thanks for the ideas here! -- Jerry, Set in the foothills of the Smokey's |
528 days ago |
This one is great. I love pictures and don’t like reading directions. I have done something smaller but I never thought about the wheels on the sled. What a great idea. Thanks Gary!! I started using all rough cut lumber for my projects. I am lucky enough to have a sawmill (with kilns) just 8 miles away, and if I preplan a little they will surface it for a very reasonable price. But most times I just run up for a few pieces on the spot and have to do surface it myself. It is still better quality and cheaper than what I can buy elsewhere and it is local lumber. -- Ron, Kutztown, PA "The reward is in the journey." |
498 days ago |
I’m curious if anyone has tried this yet? -- Gary, East TX -- The longest journey begins with a single step. |
498 days ago |
Gary, plans Now have a members download this Month on tablesaw jointing. May be of interest to you. -- Grumpy - "Always look on the bright side of life"- Monty Python |
498 days ago |
Great post Gary as 0% of my lumber is bought rough. -- Jerry, Set in the foothills of the Smokey's |
479 days ago |
Interesting take on the router sled. Any issue with the runout in the caster wheels? -- Doug, woodworking in Alabama |
478 days ago |
Nice gary, It certainly has some advantages over a full sled jig. thanks for sharing…this definatly goes in my shop project folder. -- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture. |
387 days ago |
Gary, Did this ever make it in to ShopNotes? If so what issue? I am thinking about making one this weekend. I have some 6-10 wide 5/4 cherry that needs to be milled down to the proper size and don’t have a Jointer that will handle the wider stock. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
387 days ago |
sIKE – It hasn’t been in there yet. Maybe they are saving it for something special. :-) -- Gary, East TX -- The longest journey begins with a single step. |
344 days ago |
THIS IS INDEED A VERRY INOVATIVE IDEA. I MEAN JOINTING WITH THE ROUTER I HAVE HEARD OF BEFORE BUT THE WAY YOU MADE YOUR JIG IS BRILLIANT. JUST AS I WAS THINKING MAN THAT WOULD TAKE A THOUSAND PASSES TO JOINT THE WHOLE BOARD YOU SHOW HOW YOU ONLY JOINTED TWO SLOTS FOR PLANNER SLED BARS TO FIT INTO. BRILLIANT MAN. I WILL DEFINETLY USE THIS TIP SOON -- i can do all things through christ who strengthens me |
324 days ago |
Thanks for posting. I have some 3×14 oak I couldn’t figure out how to work with. -- Robert in middle TN |
303 days ago |
Gary, I know that your super duper clamp made it in did this one make it in? Headed out to the shop to dig though my back issues. Wish they had an online index like Wood magazine. I never got to it 83 days ago, gonna make another pass at getting this done. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
303 days ago |
Gary, I just made one of these jigs last week and it works perfect! Thanks for the idea. I was wondering how I was going to joint my wide stock of elm which should be ready in a few months. -- Julian, Park Forest, IL |
281 days ago |
Julian – Glad it’s working for you. sIKE – They paid for it but haven’t printed it yet. -- Gary, East TX -- The longest journey begins with a single step. |
281 days ago |
Thanks for taking the time to explain this so well, and with pics. I love learning things like this before bed. I will fall asleep thinking about this and wake up with a better understanding of other things too. You are gifted. -- "Safe woodworking isn't just about avoiding injury, it is also about avoiding extinction." CKG |
280 days ago |
Gary, Good job! I recently finished a workbench and made a router flattening jig similar to yours. I have attached some photos to show what I did. One variation that I did was take an old shopvac floor attachment and fix it to the sled, then added some scrap strips around the sled to add to the vacuming effectiveness. I use a Clear Vue Mini cyclone and a shop vac. Everything worked great. -- "non illegitimis carborundum" |
280 days ago |
Gary I missed this when it was first posted. I done something like yours to flatten the entire board / Workbench. But I hadn’t thought about the two grooves and then running it through the planer. That is a great tip. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
250 days ago |
laflaone – That’s the method I used to flatten my workbench also. In fact if you look at the picture of my workbench you can see the jig leaning up against the wall. http://lumberjocks.com/projects/1773 -- Gary, East TX -- The longest journey begins with a single step. |
250 days ago |
The value of the information gained on this site is beyond anyone’s imagination. Thanks for the info Gary. Some day we’ll have to meet. Can’t be too far away. How far are you from Texarkana? -- Gary, DeKalb Texas |
250 days ago |
Gary – It looks like you are about 100 miles away. You are welcome to stop by any time. Just send me a PM. -- Gary, East TX -- The longest journey begins with a single step. |
250 days ago |
This is a great tip. This looks like it should be a heck of a lot easier and more reliable than the wedging the rough luimber on a sled. Thanks a bunch! -- Chris |
250 days ago |
Thanks Gary, I put it on watch so i don’t forget it ;-) -- Debt is nothing more than the 21st Century's form of slavery. |
142 days ago |
An excellent jig Gary. When I first saw it I thought it was going to be another route the whole surface and try to get it perfect but this looks much better. Focus on getting just what is required flat and parallel, two strips, and then let the planer do it’s job. Thanks for the idea, I’ve tucked this one away. |
142 days ago |
Nice. I saved this thread for later. Someday I’ll build one for myself. |
116 days ago |
Thanks so much for this build! It will certainly help me in my wood working. -- Paul, Bristol,Rhode Island |
15 days ago |
This is a very creative jig to use in the shop. I am just starting out myself and couldnt find surfaced lumber near me… just wondering when building this how do we guarantee that the material used are straight? This may sound stupid but how do we guarantee the plywood and the guides are straight to begin with? Thanks! |
15 days ago |
adroga – Well, good quality (read not Chinese) plywood is about the flattest thing you can buy. It basically comes down to what you lay them on. The two strips going down the length were cut from the long edges of the sheet of plywood. You can’t get a much straighter edge than a factory edge from a piece of plywood. The I fastened them with that factory edge to the sheet. This will get them pretty flat. I use the top of my workbench to lay the fixture on, which I machined to be flat. If you don’t have a flat workbench then you will have lay your fixture on whatever you have. Then you will have to shim your fixture flat. A nice 4 or 6 foot level will help you with this. Flat is what you are looking for not straight. It’s basically up to you to make sure that it’s flat. BTW this was my post number 9500. -- Gary, East TX -- The longest journey begins with a single step. |
15 days ago |
Thanks for the reply, just what I needed to know. Everyone is really friendly and helpful here. And congrats on #9500… : ) |
15 days ago |
It’s alwaus interesting to see the many methods to accomplish a task in woodworking. I cut rough sawn boards slightly longer than my project dimensions, then clamp the board on my workbench. With winding sticks and hand planes I then knock off high spots and remove twist. I don’t need to plane the whole surface before running the board thru the planer. I guess I’m just old fashioned. -- "Heaven is North of the Bridge" |
| Forum | Topics |
Woodworking Skill Share
2920 |
3948 |
257 |
950 |
225 |
Woodworking Trade & Swap
620 |
Coffee Lounge
2394 |
LumberJocks.com Site Feedback
524 |
