How's this for a sharpening system?
« back to Hand Tools forum
Forum topic by Dagobah posted 01-16-2017 04:29 AM 745 views 0 times favorited 6 replies Add to Favorites Watch
View Dagobah's profile
Dagobah
71 posts in 657 days
01-16-2017 04:29 AM
I was recently given my grandfather’s Stanley no. 5 and a few Narex chisels, along with some old beaters. I quickly realized that I need a way to sharpen these tools (and hopefully others) in the future. I’m new to sharpening, so I’m putting this together based on a couple hours of research. How’s this for a start?
-King Combination 250/1000 water stone (I already own this)
-Vertias Mk II Guide
-Shapton Ceramic 5000
-DMT W6XP Coarse (for flattening the Shapton & King)
A couple notes:
-I started off looking at the scary sharp method, but quickly realized it was going to get expensive
-My plan is to use the King 250 for rough stuff and the King 1000/Shapton 5000 for most of the maintenance work
-I like not having to soak the Shapton’s, but not sure it matters since I’ll be using it with the King
-Debated getting a Shapton 8000 as well, but hoping I can get away without it.
-Lots of DMT stones out there, but one in particular is both 220 grit and much cheaper than the bench stones. Not sure of the differences.
View TheFridge's profile
TheFridge
9444 posts in 1481 days
#1 posted 01-16-2017 05:03 AM
It’s a good start.
View William Shelley's profile
William Shelley
565 posts in 1464 days
#2 posted 01-16-2017 06:44 AM
I just used a cheap-as-shit sharpening brick from home depot and restored a thrift store plane to “sharp enough” in about half an hour. Also my first time sharpening. I couldn’t tell you what angle I got it to or anything. It probably doesn’t have a microbevel. It looks like garbage. But it only took a bit of fiddling of the plane to be making nice shavings.
I’m sure you won’t get worse results with the stuff you listed. But maybe just give it a try with some sandpaper or a cheap sharpening stone first before dumping money on fancy toys.
-- Woodworking from an engineer's perspective
View Robert Stockwell's profile
Robert Stockwell
8 posts in 551 days
#3 posted 01-16-2017 10:40 AM
Edge Pro is the best to sharpening tool. You can try it
View JayT's profile
JayT
5623 posts in 2206 days
#4 posted 01-16-2017 02:30 PM
I agree with Fridge that it’s a good start. I think you’ll find that adding one level that is even finer will be needed for best results, especially for paring chisels and smoothing planes. Doesn’t have to be another stone, a piece of leather glued to a board and loaded with honing compound makes a great and inexpensive strop for getting an edge where it needs to be.
View bbasiaga's profile
bbasiaga
1231 posts in 1990 days
#5 posted 01-16-2017 03:11 PM
I agree with others. If you have to buy the 5000 stone, buy an 8000 instead. I use a 1k then 8k and it works great. The Veritas jig is nice too, (i have one) but you may consider adding a cheap honing guide as well so you can more easily camber your plane blade. Or else buy the camber roller for the veritas.
Brian
View rwe2156's profile
rwe2156
2920 posts in 1475 days
#6 posted 01-16-2017 03:18 PM
IMO you need something higher than 5000.
I think for the money, the 4K/8K stone Norton sells is pretty good.
I think a strop is a good idea, too.
I recommend one like this jig with a view toward going freehand.
