Drill press
Forum topic by Kydd posted 01-14-2017 02:55 AM 485 views 0 times favorited 6 replies Add to Favorites Watch
View Kydd's profile
Kydd
4 posts in 584 days
01-14-2017 02:55 AM
I just bought the 8 inch 5 speed drill press from harbor freight with a 2.4amp motor.
I am running about 3000 rpm and I’m having a problem drilling 1 5/8” holes with fornestor bits. The bit just stops turnimy. Am I doing something wrong or is the motor just not powerfully enough?
View SuperCubber's profile
SuperCubber
1030 posts in 2370 days
#1 posted 01-14-2017 03:49 AM
I would slow it down quite a bit. Check out this chart for reference:
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View GR8HUNTER's profile
GR8HUNTER
4358 posts in 798 days
#2 posted 01-14-2017 04:28 AM
make sure bit is sharp and slow down RPMs under 1000
View Kydd's profile
Kydd
4 posts in 584 days
#3 posted 01-14-2017 12:56 PM
Ill try slowing it down.
Thank you guys.
View Kydd's profile
Kydd
4 posts in 584 days
#4 posted 01-14-2017 04:25 PM
I slowed my press to about 700 rpm and the bit went through like butter
Thank you guys for the tip.
I truly appreciate it.
View Steve Peterson's profile
Steve Peterson
387 posts in 3168 days
#5 posted 01-14-2017 05:28 PM
The motors on smaller power tools are often undersized. I have a cheap 9” bandsaw that I can easily stall the motor with just a slight push on the wood. The motor slows down and this is my hint to back off the pressure. You may be able to notice the same thing with your drill press. Lighten up the handle pressure and the motor should start turning again. Changing the belts on a drill press gives you a mechanical advantage of more torque at lower RPMs.
-- Steve
View Kydd's profile
Kydd
4 posts in 584 days
#6 posted 01-14-2017 05:44 PM
I took the tips,from the replies I got and I lowered the rpm to about 700 and the fornester bit drilled like a charm.
Thank you again for the asvice. You guys are awesome.
