Smoothing Rough Pecky Cedar
Forum topic by torea posted 01-13-2017 03:43 AM 496 views 0 times favorited 2 replies Add to Favorites Watch
View torea's profile
24 posts in 805 days
01-13-2017 03:43 AM
I recently picked up a few small boards of pecky cedar. It’s essentially two 1/2” boards glued together, one that’s smooth cedar, and one that’s pecky and rough. I’d love to smooth out the pecky side to use for some projects, but I’m worried about tear-out or just destroying the pecky-ness. Does anyone have any tips for smoothing these boards without shredding or chipping them to death?
I have a Grizzly benchtop planer and a variety of power sanders, if that helps.
Thank you!
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3648 days
#1 posted 01-26-2017 02:01 AM
I understand that the helix heads for planers are great at handling ‘problem’ grain, that may be one (expensive) solution. Shallow cuts with your planer may yield good results. If it is just one board I would break out my hand planes and have at it. It is surprising how quickly you can tame a knarly piece of wood with a hand plane
View wood2woodknot's profile
92 posts in 1909 days
#2 posted 01-26-2017 04:27 AM
SHARP – THIN CUTS. I just finished carving a 6 ft. boat oar out of a piece of 2×8 western red cedar. Blocked out the basc shape on a table saw, then all the thicknessing and shaping with only a #5 and block planes, and a 3/4” chisel. I have two garbage bags of shavings. Most problems with tearout were when I tried to take too heavy a cut or needed to touch up the tools. Watch the grain. Shearing cuts were a big help, too. I just finished thicknessing some smaller pieces for another project and a ryoba and planes were better than a band saw and scroll saw (tendency to burn).
Was not hard – just had to be careful and not rush the hand work. This was my first project with cedar. Enjoyed he experience..
-- ajh
