Thoughts on this drill press?
Forum topic by ragin_cajuns posted 01-12-2017 09:49 PM 1108 views 0 times favorited 23 replies Add to Favorites Watch
View ragin_cajuns's profile
ragin_cajuns
40 posts in 1068 days
01-12-2017 09:49 PM
Looking to add a drill press to my workshop. Thoughts on this drill press?
I’m just a hobbyist so I don’t need anything super expensive.
23 replies so far
View ihadmail's profile
ihadmail
68 posts in 710 days
#1 posted 01-12-2017 10:08 PM
I don’t see a picture or a link? I can’t help with input on any drill presses but more info would help those who can.
View MrUnix's profile
MrUnix
7036 posts in 2395 days
#2 posted 01-12-2017 10:17 PM
Doesn’t look like much to me… ;)
View Ron Aylor's profile
Ron Aylor
2649 posts in 844 days
#3 posted 01-12-2017 10:59 PM
Wow … that’s more minimal than mine …
View Karda's profile
Karda
1313 posts in 750 days
#4 posted 01-13-2017 12:54 AM
now that is low tech, go for it
Karda
#5 posted 01-13-2017 12:54 AM
ragin_cajuns
#6 posted 01-13-2017 03:04 AM
View papadan's profile
papadan
3584 posts in 3565 days
#7 posted 01-13-2017 03:29 AM
About the same as HF. Spend a little more now and get a decent drillpress.
ragin_cajuns
#8 posted 01-13-2017 03:38 AM
- papadan
recommendations?
papadan
#9 posted 01-13-2017 06:11 AM
Here’s a nice jet under 400. http://www.sears.com/jet-716000-1-2-hp-12-in-drill-press/p-SPM7773461828?plpSellerId=CPO Outlets&prdNo=6&blockNo=6&blockType=G6
Karda
#10 posted 01-13-2017 06:19 AM
how does the craftsman 10” DP rate
View HokieKen's profile
HokieKen
6997 posts in 1335 days
#11 posted 01-13-2017 12:15 PM
I have to disagree. I have the 12” C-man and it’s a good machine. The laser junk is worthless, but that’s true of any DP with the same system. Unless you never move the table and always have the same thickness stock, the position of the cross-hairs changes due to parallax. So ignore the laser part.
The reason I bought the DP to begin with is because the runout was the best of any <$500 consumer grade model I could find. The speed range is good enough for wood and most metal jobs although, as with any cheaper DP, belt changes is kinda tedious. All-in-all though, after having it for almost 3 years, I’m still glad I bought it and would recommend it for the price.
Of course, it isn’t perfect. I hate the travel stop but it seems most consumer grade benchtop models are made with the same radial stop system. The quill return spring on mine broke after about a year and I had to replace it but I haven’t read anything about that being a common ailment. The table is relatively solid but it’s too small to suit most woodworkers so you’re probably gonna want to make or buy an auxiliary table but that’s the case with most any press you find.
It’s definitely not the best DP in the world but at the price point, if I was buying another press, I’d buy this one again.
-- Kenny, SW VA, Go Hokies!!!
View HorizontalMike's profile
HorizontalMike
7770 posts in 3110 days
#12 posted 01-13-2017 12:28 PM
I have had my 8in. Craftsman DP for +25yr. It still works well, BUT about 4yr ago I broke down and finally purchased a 20in. Grizzly Floor Model DP. Having said that… I DO NOT understand why I put off buying a properly sized DP for so long.
I spent so many, Dxxmn many, years just ”...putting up with…” my too-small DP, I almost get sick thinking about it.
LESSON LEARNED: Buy as large a DP as you can EVER afford, and never look back. Don’t spend decades regretting buying TOO SMALL. Think at least 17in. to 20in. and make sure that your lowest speed is ~200rpm or less (very important for large bits).
That is just my opinion.
View JayT's profile
JayT
5957 posts in 2407 days
#13 posted 01-13-2017 12:42 PM
My opinion echoes Horizontal Mike’s. I used a small benchtop press for several years before purchasing a full size Delta at an auction. No comparison is capabilities and performance and not enough difference in cost to justify the frustration.
Biggest thing I see underestimated is the need for slower speeds. Having the capability to go down to 250 rpm or less is essential for larger bits and some metal working. Too many people think they’ll be able to “get away’ with running those bits at faster speeds, but it’s just a recipe for disaster.
ragin_cajuns
#14 posted 01-13-2017 12:57 PM
what about this if I wanted to go with a floor model
https://www.lowes.com/pd/PORTER-CABLE-8-Amp-12-Speed-Floor-Drill-Press/1000132463
ragin_cajuns
#15 posted 01-13-2017 02:34 PM
