Removing rust from hand gouges
« back to Hand Tools forum
Forum topic by Dalette posted 01-12-2017 08:40 PM 652 views 0 times favorited 7 replies Add to Favorites Watch
View Dalette's profile
Dalette
5 posts in 3341 days
01-12-2017 08:40 PM
Topic tags/keywords: rust tools gouge
Hi, i am sorry if this has been answered before. I have been given a set of hand carving tools. They are older and craft store variety and cheap. It is a set of 10 and I would say over half have some rust on the tips.
So that being said, what is the best way to remove the rust without damaging the tools. I think they could be useful.
Thank You.
Dalette
7 replies so far
View Tim's profile
Tim
3812 posts in 2015 days
#1 posted 01-12-2017 09:03 PM
There are a variety of ways of removing rust – chemical such as acid/evaporust, electrolysis, and abrasive.
For edge tools, you might as well remove the rust from the whole tool with a chemical method or electrolysis. You’ll be left with the pitting in the steel and near the cutting edge you’ll need to grind or abrade to the bottom of those pits anyway, but at least you’ve removed it from the rest of the tool. I’m not a carver, so I don’t know if there are any particular recommendations different for carving tools. If they’re cheap tools it’s probably not worth a ton of effort.
View Ron Aylor's profile
Ron Aylor
2649 posts in 701 days
#2 posted 01-12-2017 09:06 PM
Dalette – I have found that an overnight soaking in good old distilled white vinegar does the trick. Every so often I soak all my chisels, files, saws in vinegar just to freshen them up! This little trick will also sharpen you files.
View MrUnix's profile
MrUnix
6827 posts in 2253 days
#3 posted 01-12-2017 09:07 PM
Doesn’t sound like they are terribly rusted, so you might get away with just a good cleaning using a scotch-brite pad and some solvent. Otherwise, Evaporust is a great, non-destructive method. Electrolysis is another option, but it’s way messy and probably overkill for what you want to do. I’d stay away from any acids (citric, phosphoric, etc…).
View JCamp's profile
JCamp
726 posts in 605 days
#4 posted 01-13-2017 12:26 AM
I second the vinager. I’ve done a few things that way. After a day or so just pull it out an scrub it down an the rust is gone. U will need to keep them oiled after that tho or it will find its way back
-- Whatsoever thy hand findeth to do, do it with all thy might
View Karda's profile
Karda
1138 posts in 608 days
#5 posted 01-13-2017 12:53 AM
i MAYBE LYNCHED FOR THIS BUT i HAVE HEARD COKE does real well, never done it because my wife is a pepsi drinker but worth a try and won’t damagre the blades
MrUnix
#6 posted 01-13-2017 01:14 AM
i MAYBE LYNCHED FOR THIS BUT i HAVE HEARD COKE does real well, never done it because my wife is a pepsi drinker but worth a try and won t damagre the blades
- Karda
The acids in Coca-cola will eat good metal if you are not careful.
Ingredents:
Carbonated water, high fructose corn syrup, caramel color, phosphoric acid, natural flavors, caffeine.
Source: Coca-cola product facts
PS: Pepsi is the same (pepsicobevragefacts.com)
Dalette
#7 posted 01-13-2017 07:38 PM
THANK YOU EVERYONE! SO MANY DIFFERENT AND HELPFUL IDEAS, I WILL TRY THE SIMPLE ONES FIRST AND GO FROM THERE… i’LL POST A PIC BEFORE AND AFTER…
