Tilt-out Drill bit storage
Forum topic by Ripthorn posted 1025 days ago 698 views 0 times favorited 1 reply Add to Favorites Watch
View Ripthorn's profile
Ripthorn
506 posts in 1182 days
1025 days ago
Hi guys, I am in the process of designing a drill bit storage cabinet and need a little help. I want to put most of my bits in little tilt-out blocks that have holes drilled in them. The idea is that they would be vertical while the cabinet is closed, but could tilt out up to 20 degrees or so to make it easier to pull the bits out. My question is: what methods have you used for actually making and installing these? Would it be sufficient to just put a small pin into either side of the block and then put some sort of a stop at the angle I want? I hope this is making sense. I saw one a while back, but didn’t pay close enough attention to exactly how it was done any ideas and examples would be very welcome.
1 reply so far
View Gregn's profile
Gregn
1639 posts in 1181 days
#1 posted 1025 days ago
Wouldn’t routing a cam action on the bottom of the box with the pins set so that it naturally comes to a stop without having to add a stop. It would also allow for dust to settle to the bottom of the case, and prevent dust build up and binding with a stop. That would be the way I’d do it if I wanted them to tilt out a few degrees. I would however mount rare earth magnets to hold them upright until I wanted to tilt them out.
