Glass insert for shaker style cabinet door?
Forum topic by HickWillis posted 01-12-2017 01:34 PM 751 views 0 times favorited 5 replies Add to Favorites Watch
View HickWillis's profile
HickWillis
114 posts in 807 days
01-12-2017 01:34 PM
Hi everyone! I’m building some new cabinet doors (shaker style) and want to do one of them with a glass insert. Can I follow the same process to build it as I am doing the rest of the doors? I.e., cut the rails and stiles to match the thickness of the glass and slide the glass into that groove? I’m not sure if I would run into any problems doing it this way.
-- -Will
5 replies so far
View Alongiron's profile
Alongiron
649 posts in 2841 days
#1 posted 01-12-2017 01:47 PM
Yes Build them all the same. When you are ready to put the glass in, you will just need to place the door face down on your work bench and put in a rabbeting bit in your router the same thickness as the depth of the grove. you will need to square up the corners with a sharp chisel after you have gone around all 4 sides. Set your glass in place..no glue.. and cut some stops to hold it in place from the back side.
Hope this helps
Steve
-- Measure twice and cut once.....sneak up on it! Steve Lien
Alongiron
#2 posted 01-12-2017 01:50 PM
http://designsbystudioc.com/how-to-use-router-cut-rabbet-frame/?print=print
View Ron Aylor's profile
Ron Aylor
2649 posts in 796 days
#3 posted 01-12-2017 01:54 PM
Will – What are you doing with the rest of the doors? The glass should be removable in case it breaks and needs replacing. I used wooden strips (akin to caulking) to hold the glass in the door and sides of a lantern … perhaps something like this would work for you.
HickWillis
#4 posted 01-12-2017 07:17 PM
Hope this helps
Steve
- Alongiron
Ah ha, perfect. Thanks Steve
-- -Will
View pintodeluxe's profile
pintodeluxe
5757 posts in 2961 days
#5 posted 01-13-2017 05:34 AM
No, I wouldn’t trap them in a groove. As Ron mentioned, a rabbet with glass stops is a better way.
