Powermatic 15by question
Forum topic by Clk51212 posted 01-11-2017 11:35 PM 541 views 0 times favorited 7 replies Add to Favorites Watch
View Clk51212's profile
Clk51212
34 posts in 601 days
01-11-2017 11:35 PM
Looking for new planer there’s one listed on craigslist looked at in excellent condition guy is asking 2000. Would rather have a powermatic then grizzly for about same price any thoughts also Manuel says it needs a 40amp circuit that sounds odd the jet unit with hh says 30amp
7 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3741 days
#1 posted 01-26-2017 02:24 AM
What power requirements does this saw have? Can your shop match those requirements?
View AHuxley's profile (online now)
AHuxley
666 posts in 3350 days
#2 posted 01-26-2017 04:25 AM
I am looking at the manual on the Powermatic site and both the 15S and 15HH show a recommendation for a 30 amp circuit. It also shows 30 amps in the spec section. The single phase PM209 shows 40 amps though.
View bonesbr549's profile
bonesbr549
1558 posts in 3095 days
#3 posted 01-26-2017 01:19 PM
- AHuxley
Reason is the 209 is a 20” 5hp machine. In general 3hp will run on 30A circuit just fine 5hp will need the higher requirement.
5002 posts in 2522 days
#4 posted 01-26-2017 01:34 PM
I’m running all my 3 HP tools (including a 15” planer) on 20 amp circuits and have yet to trip a breaker. I have 2-5 HP tools that run on 30 amp circuits. There are several reasons most manufacturers suggest an oversized circuit, but generally most folks (I think) do it the same way I do.
View sawdustdad's profile
sawdustdad
364 posts in 913 days
#5 posted 01-26-2017 02:34 PM
I run two different 5hp planers on 30A 240V circuits. These are real 5hp motors, Baldor, not the fictitious “5hp developed” rated stuff (shop vac, etc.) And I’ve run them hard, planing full width 20 inch panels on the 20 inch planer, and heavy cuts with the 12 inch planer/molder.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View msinc's profile
msinc
430 posts in 532 days
#6 posted 01-27-2017 02:28 AM
Well, you can get away with a lesser amp rated circuit for two reasons, one is that they usually design in some overkill and two is because the start capacitors give a little delay. You really should only need the high amp draw on startup unless you are horsing the machine. I will say that it can sometimes be hard on the start capacitors when they operate just at trip amps, so it’s kind of not a good idea. It doesn’t just mean a change to a higher rated breaker either…you have to have the correct gauge wire running to the machine to support the amp load.
View KelleyCrafts's profile (online now)
KelleyCrafts
2880 posts in 768 days
#7 posted 01-27-2017 07:53 PM
I run the single phase 5hp PM209 on 30amp 240V just fine.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
