Ridged ts2400-1 table saw+Dado blade
Forum topic by Jrobinson37 posted 01-11-2017 11:32 PM 502 views 0 times favorited 5 replies Add to Favorites Watch
View Jrobinson37's profile
Jrobinson37
13 posts in 408 days
01-11-2017 11:32 PM
Topic tags/keywords: tablesaw bandsaw biscuit joiner carving tool chisel drill-driver drill press lathe miter saw planer router scroll saw
I’m the proud owner of a ridged ts2400-1. Was wondering if anyone has ever put a Dado blade on it. I’ve read that it only takes 6” dad’s but that doesn’t make much sense to me. Could someone please help before I spend over 125$ on a plate and a Dado blade. Since it’s a discontinuedifferent model there is hardly any info about this.
5 replies so far
View papadan's profile
papadan
3584 posts in 3276 days
#1 posted 01-12-2017 12:07 AM
Yes it will handle an 8” dado stack. I make all my zero clearance inserts out of laminated flooring.
View knotscott's profile
knotscott
7877 posts in 3283 days
#2 posted 01-12-2017 12:14 AM
Either 6” or 8” may fit on the arbor, but I think what they’re getting at is that it’ll have an easier time spinning the smaller stack….it’s lighter and easier on the motor and bearings. Which stack are you looking at?
View crank49's profile
crank49
4029 posts in 2879 days
#3 posted 01-12-2017 02:34 AM
Since, by definition, a dado blade is only going to cut dados, why push your luck and stress the motor shaft arbor. A 6” blade will easily cut over 1 1/4” deep and thats about a 1/2” more than I ever need.
Jrobinson37
#4 posted 01-12-2017 02:13 PM
Thanks for the input and info. I was probably just going to buy something cheaper. Fairly new to woodworking and have spent a lot of money in the last few months on equipment. Oshlun has a 6” for 70$ on amazon. That’s a little more then id like to spend tho.
knotscott
#5 posted 01-12-2017 03:35 PM
Thanks for the input and info. I was probably just going to buy something cheaper. Fairly new to woodworking and have spent a lot of money in the last few months on equipment. Oshlun has a 6” for 70$ on amazon. That s a little more then id like to spend tho.
- Jrobinson37
The Oshlun is a really good bang for the buck. Better to spend it wisely than to waste it. I wouldn’t recommend spending anything on the junk that’s routinely ~ $50 or less. Blades are where the “rubber hits the road” with table saws….the saw will never be better than the cutters you put on it. I’ve never regretted an upgrade on good blades/cutters.
