3/4" hvlp plug/coupler connector?
Forum topic by bringitonhome posted 08-28-2010 03:52 AM 2381 views 0 times favorited 3 replies Add to Favorites Watch
View bringitonhome's profile
bringitonhome
28 posts in 3103 days
08-28-2010 03:52 AM
Hi folks – having a bit of a problem here.
Last year a bought a small hvlp system. It’s worked ok, but the gun leaves a bit to be desired. So, I purchased a new one and brought it home only to find that the connector wont fit. The gun has 3/8” NPT male threads (for which I had purchased a 3/8” quick connect plug). Turns out that my sprayer hose has a 3/4” quick connect coupler. It seems that 1/4” and 3/8” are the standard sizes. I’ve looked at both big boxes and HF, and they only carry those sizes. No 3/4” fittings to be found anywhere.
The old gun is cheap plastic and the plug is actually part of the body – so nothing to be reused there. Has anyone ever seen 3/4” fittings before? Or can anyone offer any clever ideas of how I can make this connection? :)
Brainstorming…
3 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 3071 days
#1 posted 08-28-2010 04:07 AM
Not sure I can be of much help. In general, the conversion guns use standard air quick connects – 1/4 normally the air pressure is set to 20 to 40 psi. . Turbine guns on the other hand usually have a much wider intake ( 3/4 is what Capspray uses http://www.google.com/products/catalog?hl=en&q=quick+connect+hvlp&um=1&ie=UTF-8&cid=6011534133332582747&ei=vW14TNbNOYyalgePmtWhAg&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDUQ8wIwAg#
But the turbine generates air at 10 psi or less ( High Volume Low Pressure ) that is in part why the hose is much wider. The point I am trying to make is that if you get a conversion gun ( it converts high pressure air to low pressure air ) you can’t run that from a turbine, and if you have a turbine gun you can’t run that from a compressor. So I may have misunderstood, but it sounds like you have a turbine with a hose with a 3/4 fitting that you are trying to attach to a conversion gun ( though that would normally be 1/4 fitting ) if that is what is going on, a coupler won’t work.
View PurpLev's profile
PurpLev
8536 posts in 3676 days
#2 posted 08-28-2010 04:28 AM
from what it sounds like you got a gun that is to be used with a regular high-capacity air compressor and you’re trying to make it fit a turbine unit which uses different connections and hoses all together. I have not found anything that would make those 2 work as of yet.
bringitonhome
#3 posted 08-28-2010 09:24 PM
yes that’s exactly it!
i have a turbine system. I thought conversion gun – regulator = turbine gun. Guess not. It seems like the overwhelming majority of spray guns for sale are conversion guns. The few turbine guns i’ve found cost over $300. Some over $500. Since the whole rig cost me ~$120, that’s a bit more than i was looking to spend.
