angle/bevel question???
Forum topic by Belg1960 posted 01-10-2017 11:12 PM 851 views 0 times favorited 20 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1073 posts in 3187 days
01-10-2017 11:12 PM
Topic tags/keywords: question
Guys, I’m building a four sided birdhouse where the roof peak is cut at 45 degrees on either side and butts into a roof thats cut the same way.
Here is my VERY crude drawing of what I need help with (circled in red). Is there a calculator that I can use on line for this?
-- ***Pat*** Rookie woodworker looking for an education!!!
20 replies so far
View GR8HUNTER's profile
GR8HUNTER
4579 posts in 834 days
#1 posted 01-11-2017 12:00 AM
are you trying to find the angle of it? ..... or what ?
Belg1960
#2 posted 01-11-2017 12:03 AM
right the angle and the bevel for it to sit flat on the other roof.
View jbay's profile
jbay
2607 posts in 1021 days
#3 posted 01-11-2017 12:43 AM
35.26 miter, 30 bevel… ?
View ChuckV's profile
ChuckV
3161 posts in 3649 days
#4 posted 01-11-2017 12:47 AM
[On second thought, what I suggested was wrong!]
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
Belg1960
#5 posted 01-11-2017 03:04 AM
jbay, thanks can you share how you calculate something like this?
View jbay's profile
jbay
#6 posted 01-11-2017 03:13 AM
I took a few minutes to draw it in Sketchup,
Then I went to this site and entered 90 deg for the wall angle and 45 deg for the spring angle to double check/confirm what I measured in Sketchup.
If your asking me how to do the math, I have no clue…
117204 posts in 3699 days
#7 posted 01-11-2017 03:17 AM
Good to know J wish I was good at Sketchup or had the slightest clue.
View oldnovice's profile
oldnovice
7142 posts in 3490 days
#8 posted 01-11-2017 06:59 AM
I did the same thing in Creo modeling and got the same answers … !
TopamaxSurvivor
18361 posts in 3798 days
#9 posted 01-11-2017 08:31 AM
If you can find a good book on using a framing square, it will tell you how to cut those angles. I do not remember how, been about 50 years too long ago ;-)
Belg1960
#10 posted 01-11-2017 10:17 AM
- jbay
I really appreciate the effort and the link that will be very helpful in the future. Is the wall angle 90 degrees because it is plumb or because it was cut at a 45 degree angle?
View Tony_S's profile
Tony_S
908 posts in 3205 days
#11 posted 01-11-2017 11:12 AM
- jbay
I don’t know if the 30 degree bevel is correct(in this instance) J? Did you try it Pat?
30 degrees would work if there was a bevel on both roof sections, but there isn’t, the left hand section runs straight through….the only bevel is on the on the right hand section.
Just to confuse matters even more…if you did crown molding this way on an inside corner, 30 would still be correct, but only because the right hand side would be coped into the left hand side.
On the other hand…..I could be completely effed in the head? I’m just confusing the hell out of myself now. To early for this chit. lol!
Got a lot of respect for the old timers who could ‘stick frame’ gables and dormers properly and accurately….it’s a lost art anymore.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View dbray45's profile
dbray45
3320 posts in 2898 days
#12 posted 01-11-2017 12:58 PM
I don’t know the angles that you have for your roof line but with a couple adjustable squares will make short work out of it.
If your roof is 30 degrees and you want to come off it 90, then the angle will be 60 for the crown. When you come off it at an angle, it gets different.
Set one square for the crown of the new roof off the main roof. Take the other, and set it for the angle of the new roof – line it up for the angle. Take that to the chop saw and it works every time.
-- David in Damascus, MD
#13 posted 01-11-2017 01:07 PM
I fight angels all the time I guess it’s my dyslexia, not exactly sure what you’re talking about David ? If you have a photo of what the two squares look like as your describing it,it would make things clearer at least to me,if it’s not to much trouble?
View Snipes's profile
Snipes
185 posts in 2367 days
#14 posted 01-11-2017 01:09 PM
for cutting rafters.. on framing square 12 on the tongue 17 on body. speed square middle is for hip, use 12/12. without doing it i believe j right on the 35 but think 45 on the bevel.
-- if it is to be it is up to me
View jbay's profile
jbay
#15 posted 01-11-2017 02:54 PM
Tony, your effed in the head…lol go drink some coffee! (I drink Monsters myself)
A1Jim, angels are a lot harder to fight than angles…
I just went and tried it, Worked perfect
