14 inch Reliant band saw will not start
Forum topic by lmd posted 01-20-2008 07:00 PM 1538 views 0 times favorited 5 replies Add to Favorites Watch
View lmd's profile
lmd
3 posts in 3982 days
01-20-2008 07:00 PM
I have a Reliant band saw that will not start, it is not the safety switch because I tried that so does anyone have any other suggestions on what it might be. It worked fine before we moved to another state and now it will not even start when pushing the start button on
5 replies so far
View CoolDavion's profile
CoolDavion
437 posts in 4027 days
#1 posted 01-20-2008 09:48 PM
Does anything else work in the same outlet?
-- Do or do not, there is no try!
View GaryK's profile
GaryK
10262 posts in 4191 days
#2 posted 01-20-2008 09:49 PM
Ask Karson. He has a Reliant.
View lmd's profile
lmd
#3 posted 01-20-2008 09:50 PM
I took apart the switch on it and cleaned it up and now it works again, thanks for your help
View Thos. Angle's profile
Thos. Angle
4444 posts in 4165 days
#4 posted 01-21-2008 12:04 AM
Oh thank heavens; I was scared it was from changing states!! LOL
View MLK's profile
MLK
82 posts in 4013 days
#5 posted 01-21-2008 02:21 AM
Doe’s the motor make any sound when the switch is pushed to the on position? If it does you may have a bad capacitor or a binding in the drive train. If there is no noise I would first check the line side of the switch and see if I have power going to it, then the load side of the switch. If you’re running it off an extension cord the cord has to be the proper size if it’s to small this could cause the problem.
