Replacing JCB Sander Backing Pad? Will Bosch or other work?
Forum topic by Ielle posted 01-10-2017 09:00 PM 587 views 0 times favorited 2 replies Add to Favorites Watch
View Ielle's profile
1 post in 437 days
01-10-2017 09:00 PM
Topic tags/keywords: question sander jcb replacement parts sanding pad backing pad repair
Any advice/ideas are much appreciated!
I have a JCB Sander (360W 1/2 SHEET SANDER JCB-SS360) which is just over a year old. The black backing pad, which is part of the sanding plate, is already quite worn and sanding sheets aren’t having good, uniform contact with it.
I want to replace the pad or the entire plate if need be. I couldn’t find replacement parts online, so I called JCB and was informed that they can’t source replacement pads or plates! (WTH – they make it, why can’t they source it!?) They suggested I try Solent Tools and Tooled-Up, but neither of them can source them either.
Has anyone else replaced a JCB sanding plate or backing pad? The closest thing I can find is a Bosch “replacement backing pad suitable for the Bosch GSS23AE & PSS23A orbital sanders.Part No: 2608000072.” Anyone know if that will work? It looks quite similar from low-quality online pictures, but of course you can’t tell until you see it in person.
I don’t believe in throwing away tools which work or can be used for parts, and on principal always prefer repairing what I have to buying new. Though, if I had enough money I would sell the JCB for someone else to repair and buy a Makita or Milwaukee that I know will last for many years. /sigh/
[As a side note, I’ve since learned that JCB has “licensed its name and image to a line of consumer power tools, manufactured by Alba PLC.” (source So, they aren’t even made by JCB. :/ I really hate when manufacturers engage in those kinds of shenanigans and mislead the public. I won’t be buying JCB again.]
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3648 days
#1 posted 01-26-2017 02:29 AM
Any success Michelle in finding a solution?
View JoeinGa's profile
7733 posts in 1943 days
#2 posted 01-26-2017 02:00 PM
You might be able to do this yourself.
That 1/2 sheet sander more than likely uses the same material that most 1/4 sheet sanders use. Years ago I replaced the pad on an old Makita sander I had. I went to an “Arts & Craps” store and found some heavy felt-like material that had a cork backing. Cut it to size and used contact cement to adhere it to the plate which I had cleaned off using Goof-off” and acetone.
