Forum topic by mzimmers | posted 08-27-2010 12:24 AM | 7394 views | 0 times favorited | 20 replies | ![]() |
Hi, all – My workbench is a solid core door (32” x 80” if memory serves). A few years back, I put some ugly vinyl flooring squares over the top to protect it. It’s time to refresh those. While I was poking around Lowe’s home page, looking at vinyl, it occurred to me that I could use some kind of hardwood flooring instead. I know little about the relative properties of different woods, though. Can someone suggest something hard and durable that might work for this? Thanks. -- M. Zimmers |
20 replies so far
#1 posted 08-27-2010 12:31 AM |
Hardboard works well. -- I don't make mistakes, I have great learning lessons, Greg |
#2 posted 08-27-2010 12:49 AM |
I thought about MDF, but if I’m going to sacrifice the durability and convenience of vinyl, I think I’d at least like it to look nice. Any ideas in solid wood? -- M. Zimmers |
#3 posted 08-27-2010 01:26 AM |
I agree with Greg. You could make a hardboard top with a solid wood edge look nice. Hardboard (masonite) is not MDF, technically, although it is all sawdust, I guess… -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#4 posted 08-27-2010 02:00 AM |
I built a workbench and used old 2×4 for a top foundation and then used 3/4 MDF screwed on top of that.. then a sheet of hardboard screwed down on top of that with the screws counter sunk of course and used a router to ease the edge all the way around. This way if the top ever gets damaged to the point where it has to be replaced I only have to spend the money for the hardboard… Paul |
#5 posted 08-27-2010 02:12 AM |
I know I am bias, but I don’t think anything beats bamboo. In my case, I use bamboo flooring. Bamboo is so tough and it can withstand anything, -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#6 posted 08-27-2010 02:48 AM |
Yeah, bamboo sounds good. Do the flooring planks butt flush, or is there a little V groove between them at the top? Now I have to find some that are at least 80” long; the ones listed at Lowe’s seem to be 75”. Thanks for the idea. -- M. Zimmers |
#7 posted 08-27-2010 03:40 AM |
Engineered flooring works good. Easy to install,easy to repair or replace. -- Life is good. |
#8 posted 08-27-2010 04:44 AM |
I’ve had 3/4” ACX on my workbench/outfeed table for the past five years and – although it will never win any beauty pagents – it’s holding up just fine. I drag a paint scraper over it every year, or so, and slop on a fresh coat of whatever leftover poly I have sitting around. My benches take too much of a beating to try for the furniture look. – lol -- Adversity doesn't build character...................it reveals it. |
#9 posted 08-27-2010 05:22 AM |
In solid wood, an american beech, hard maple or an ash top surface could be utilized as a top -- Phil |
#10 posted 08-27-2010 05:26 AM |
I like cork flooring -- "Good artists borrow, great artists steal”…..Picasso |
#11 posted 08-27-2010 04:35 PM |
Re bamboo – My bamboo flooring has tongue and groove sides and no special treatment at the end. I put down 2 layers of MDF, then the bamboo on top of that. I also ran 8/4 oak around the perimeter. It’s VERY heavy, which is what you want . You can see it in my workshop pictures. It’s not as clean as in the picture any more. It’s been used a lot. It’s is VERY rugged. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#12 posted 08-27-2010 05:08 PM |
Pretty much all prefinished flooring has a vgroove on the edge, which would drive me nuts on a bench top. I second the hardboard with a hardwood edging. Easy on cutting tools, cheap and easy to replace. A coat of linseed oil will help prevent glue sticking, water absorption, etc. I tacked mine down with brass screws, set flush, over a solid core door. |
#13 posted 08-27-2010 05:36 PM |
So, where would I get a hardboard panel to screw to my existing workbench? Everything I see on Home Despot and Lowe’s is in completed doors. Home Despot does have this: Though I wonder about the durability, the price is right, and installation would be pretty easy. Thoughts? -- M. Zimmers |
#14 posted 08-30-2010 05:33 PM |
HD has hardboard. It’s in the plywood/MDF/particle board aisle. Look for pegboard (same stuff, but with holes); it will be right next to it. |
#15 posted 08-30-2010 05:49 PM |
Whatever is 1) Local, 2) Inexpensive, 3) Hard. Google for Chris Schwarz Workbench. He wrote the book on traditional workbenches. For newer ones, the design is different, but the material qualifications are the same. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
