NEED GUIDANCE ON MATERIAL
Forum topic by GPM posted 1002 days ago 657 views 0 times favorited 7 replies Add to Favorites Watch
View GPM's profile
GPM
24 posts in 1002 days
1002 days ago
I am in the process of finally setting up my shop the way I want it. This includes lots of deep and wide drawers. I have built the cabinets and am ready to start on the drawers. I am also trying to use up as much stock as possible that I already have on hand.
So for the drawer box I am using an A/B 3/4” plywood on all four sides. The front will be something nicer. The big question is for the bottoms. I have a large stack of 1/2” x 12” x 50” industrial shelving that is pine. This stuff is old so it is dry and fairly hard. I would like to use these for the drawer bottoms. I can biscuit and glue up wider pieces as necessary.
Question – on the sides/back I intend to use biscuits, glue, and screws for joinery and run a groove for the bottom. If I use the pine boards, can I join them to the drawer frame in any way? How much would they actually move if they are 30” wide? Can I glue them and tack them on two sides? Four sides?
Any wisdom is appreciated.
Thanks
Greg
7 replies so far
View PurpLev's profile
PurpLev
7764 posts in 1820 days
#1 posted 1002 days ago
I think 1/2” plywood would be strong enough – and lighter, all that 3/4” adds lot of weight.
to attache the bottom – just groove the drawer sides, and leave the back open, then slide the bottom in, and attach to the back of the drawer with a single screw in the center.
View Viktor's profile
Viktor
467 posts in 1590 days
#2 posted 1002 days ago
You can calculate amount of shrinkage using these on-line calculators.
http://www.woodworkerssource.com/movement.php
http://www.woodbin.com/calcs/shrinkulator.htm
It will all depend on your climate (seasonal humidity fluctuation) and shop environment (air conditioning, heating). For 30” wide pine ~1/3” of movement could be expected.
View GPM's profile
GPM
#3 posted 1002 days ago
I am needing to make these drawers super strong. A 30” wide by 24” by 12” high drawer will hold a lot of tools/power tools. It could be 200 pounds including the weight of the drawer. That is why I chose 3/4” for the drawer boxes.
Vicktor thanks for the links. The solid wood will definitely move a bit.
9I think I might go for the 7/16” plywood for the bottoms.
Any other thoughts?
Thanks
View NathanAllen's profile
NathanAllen
383 posts in 1316 days
#4 posted 1002 days ago
I’m more of favor to use the ply for the bottom and the stock for the boxes, solid wood drawer floors is asking for a failure.
View Jim Finn's profile
Jim Finn
1068 posts in 1094 days
#5 posted 1002 days ago
a 1”x2” stiffener under the bottom will help.
-- In God We Trust
View GPM's profile
GPM
#6 posted 1001 days ago
Thanks guys. You definitely helped me think this through. I am on a medical leave right now and I have a fair amount of brain fog for now.
View wseand's profile
wseand
1549 posts in 1213 days
#7 posted 1001 days ago
Welcome to the forum.. I am with Mr. Finn some sort of cross pieces or stiffeners. Post some pics or show us your shop if you get a chance.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
