Broken plane cheek
Forum topic by nashbok posted 08-26-2010 08:03 PM 1573 views 0 times favorited 12 replies Add to Favorites Watch
View nashbok's profile
nashbok
27 posts in 2985 days
08-26-2010 08:03 PM
Topic tags/keywords: plane
I’ve got a pre WWI Stanley #5 (needs restoration) with a size-able chunk of the left cheek missing. How much strength does the cheek add? Should I bother restoring it or relegate it to the parts pile?
Thanks.
Kevin
12 replies so far
View poopiekat's profile
poopiekat
4371 posts in 3851 days
#1 posted 08-26-2010 08:19 PM
Yikes… either parts, or look for another plane body on eBay. They do come up from time to time. Like this one: http://cgi.ebay.ca/VINTAGE-WOOD-PLANE-STANLEY-NO-5-ADJUSTMENT-FROG-BASE-/360292692394?pt=LH_DefaultDomain_0 Though it too has a ‘chip’ missing… but it’s only 99 cents, so far. Also: http://cgi.ebay.ca/Old-Stanley-5-Corrugated-Plane-Base-Frame-Part-/160467463558?pt=LH_DefaultDomain_0
which has a corrugated base. Be sure the frog mount is the same as your original one, or the frog may not seat right. Bring ‘em back alive!
View b2rtch's profile
b2rtch
4863 posts in 3165 days
#2 posted 08-26-2010 08:23 PM
I would not bother with it
-- Bert
nashbok
#3 posted 08-26-2010 08:46 PM
Thanks for the info… I only paid $5 bucks for it, so I’m not out too much. ;)
For the record, the salesman at Woodcraft told me it wasn’t a big deal.
nashbok
#4 posted 08-26-2010 10:04 PM
Will do.
nashbok
#5 posted 08-27-2010 02:03 AM
Pictures are below…
View Broglea's profile
Broglea
685 posts in 3208 days
#6 posted 08-27-2010 02:11 AM
That should be OK. The proof is in the pudding. Sharpen the blade and see how she cuts.
b2rtch
#7 posted 08-27-2010 02:22 AM
I AM SURE YOU CAN USE IT. I WAS SAYING : DO NOT BOTHER FIXING IT.
-- Bert
nashbok
#8 posted 08-27-2010 02:22 AM
The blade is rough too….very dull
so is the cheek meant to protect the frog, add strength, make it look better, or all of the above? I’m guessing all of the above.
nashbok
#9 posted 08-27-2010 03:43 AM
10-4 b2rtch
nashbok
#10 posted 08-27-2010 07:36 PM
That’s a fairly sizable chunk Boise. A bit worse than mine :) —which is encouraging.
View Gofor's profile
Gofor
470 posts in 3904 days
#11 posted 08-28-2010 04:16 AM
If the sole doesn’t flex, it will work. Might want to ease the edge of the broken area a bit if you plan to use it on a shooting board, which probably would not be a good use for it in this condition, but other than that it looks like its usable.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View docholladay's profile
docholladay
1287 posts in 3176 days
#12 posted 08-28-2010 05:00 AM
Personally, I would sharpen the blade, lap the sole and see how it goes. I think it will be ok. The main thing is that the sole needs to be flat. If it is too un true, then you might rethink, but as long as the sole can be flattened and the iron sharpened, you should be good.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
