Worksharp 2000 issues
« back to Woodcarving forum
Forum topic by Bonvivant1 posted 01-09-2017 04:47 PM 656 views 0 times favorited 8 replies Add to Favorites Watch
View Bonvivant1's profile
Bonvivant1
31 posts in 1147 days
01-09-2017 04:47 PM
Hello all!
Long time lurker! Thank you for all of your knowledge. I have learned so much from this site.
I have recently started wood carving. I have purchased good tools but I am having a hard time sharpening correctly. In an effort to learn this skill, and therefore, be a better carver, I have done a few things. First, i have watched almost all the video’s on Youtube (it seems) on sharpening carving chisels. Second, I made purchases. I purchased a WS 2000 off of craigslist. I am really kicking myself because I should have waited and gotten a WS3000. It seems all the best accessories are for the WS3000. I also purchased a fine Dia stone; flexcut honing kit and a strop.
Now my problems. First, I have tried sharpening a #2 sweep gouge on the stone (without the WS2000). The results, after honing, were horrible. I think I messed up the angle of the bevel. This is after watching countless videos on Youtube with regard to sharpening. I just can’t keep the bevel angle correct.
Now I want to try the WS2000 Edge Vision to further ruin this fine chisel. The problem is the edge vision only goes to 320 grit. I can’t go any finer because it appears that Worksharp doesn’t make any finer grits for the edge vision (for the WS 2000 at least). So what do I do? Do I try to freehand it on top after I use the edge vision? this has not worked out with the Dia Stone. Do I try to make a finer grit edge vision disk? Seems like I could do it with some patience. I know I should take a class. I am looking into it. In the mean time, does anyone have any thoughts?
Also, has anyone tried using the leather honing kit from the WS3000 on the WS2000? Should I just buy the felt wheel for the WS2000? I have heard that they are not good for polishing wood carving chisels.
Any help for this lost newbie would be greatly appreciated!
-- You took your first pinch like a man and you learned the two greatest things in life...Never rat on your friends and always keep your mouth shut.--Jimmy Conway
8 replies so far
Bonvivant1
#1 posted 01-09-2017 07:50 PM
No one?
View DrDirt's profile
DrDirt
4492 posts in 3915 days
#2 posted 01-09-2017 08:03 PM
The leather wheel for the WS3000 is great for carving tools.
I do not use it for flat chisels nor plane irons. I run those on a piece of leather on a hunk of MDF,
Similarly – I only used the WS3000 wheel to set the bevel with the 320grit (and just on the glass) I don’t used the slotted wheel… since I used up that paper. I think the ability to watch the edge is not that helpful, I just put the chisel in for 2-3 seconds, then look at the edge… stick it back in for a few seconds then look at it.
I took a carving class, and they had a bunch of WS3000’s with the leather wheel to keep everyone sharp… then I got one for Christmas.
Bonvivant1
#3 posted 01-09-2017 11:21 PM
Does anyone use the leather wheel on a WS2000? I have the WS2000, not the 3000.
Bonvivant1
#4 posted 01-10-2017 03:11 PM
No one?
View coxhaus's profile
coxhaus
93 posts in 1067 days
#5 posted 01-10-2017 03:42 PM
WS2000 turns too fast. I would think the polishing wheel would be good on a WS2000. I own a WS3000.
Bonvivant1
#6 posted 01-10-2017 04:30 PM
Will the polishing wheel ruin the carving chisels?
View papadan's profile
papadan
3584 posts in 3541 days
#7 posted 01-11-2017 02:59 AM
What is the size of the belts on the WS2000?
View alittleoff's profile
alittleoff
541 posts in 1449 days
#8 posted 01-11-2017 03:39 AM
I just looked, didn’t know which one I had. I have the 3000. I’ve used it to sharpen chisels, and have used the leather honing wheel with good results. I don’t see why you can’t cut any sand paper you want to fit the glass wheel and glue it on. 3m makes a good adhesive for sand paper
