dowelling jig
Forum topic by buckbuster31 posted 01-09-2017 02:41 PM 582 views 0 times favorited 16 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
232 posts in 390 days
01-09-2017 02:41 PM
what is a good dowell jig that wont break the bank? I would love to stay in the 75 and under category. I am not using for joints as much as lining up
16 replies so far
View GR8HUNTER's profile
GR8HUNTER
3116 posts in 587 days
#1 posted 01-09-2017 02:44 PM
did you ever think of biscuit jointer ?
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View Lazyman's profile
Lazyman
1565 posts in 1261 days
#2 posted 01-09-2017 02:55 PM
+1 on the biscuit joiner recommendation if your primary goal is to make it easier to line up. Getting dowels properly aligned might actually makes it harder to get the joints lined up. Biscuits were primarily invented to make alignment easier. Dowels on the other hand are sort of a lazy mortise and tenon alternative, though might be a better laltentive if you need added mechanical strength in the joint.
buckbuster31
#3 posted 01-09-2017 02:58 PM
no, I don’t need any additional strength… just using to line up!
buckbuster31
#4 posted 01-09-2017 03:01 PM
its for a large table top and the pieces are jointed correctly, just tough to get them lined up along that large of a span
buckbuster31
#5 posted 01-09-2017 03:03 PM
and a biscuit jointer may be a little out of my price range….
View rwe2156's profile
rwe2156
2749 posts in 1355 days
#6 posted 01-09-2017 03:07 PM
check your local pawn shop you may find one in there cheap.
buckbuster31
#7 posted 01-09-2017 03:09 PM
lol, I live in a town with one stop light, one restaurant and no pawn shops!! nothing is very close either. I may just bite the bullet and buy a dewalt
View lew's profile
lew
11896 posts in 3629 days
#8 posted 01-09-2017 03:13 PM
Woodcraft has several models- here’s one
http://www.woodcraft.com/product/811565/deluxe-doweling-jig.aspx
As others have mentioned, a biscuit joiner is probably the best tool for this application.
View htl's profile
htl
3491 posts in 1033 days
#9 posted 01-09-2017 03:25 PM
Home depot has a couple a doweling jigs to choose from that are inexpensive for the few times you may need it.
Here
Harbor freight has one and others also sell the same one but not really impressed with this one. $14.???
-- Learn More About Making Wooden Models. An Index Of My Model making Blogs. http://lumberjocks.com/htl/blog/116729
buckbuster31
#10 posted 01-09-2017 03:35 PM
biscuit it is
buckbuster31
#11 posted 01-09-2017 03:37 PM
will a biscuit work for doing end grain to end grain like a dowel will? I need it for a rocking horse plan im doing where mortise and tennon is next to impossible. in the plan it calls for a 3/8 dowel. do you think the biscuit there will work as well?
9770 posts in 3522 days
#12 posted 01-09-2017 03:45 PM
116813 posts in 3451 days
#13 posted 01-09-2017 04:00 PM
View hairy's profile
hairy
2596 posts in 3406 days
#14 posted 01-09-2017 04:16 PM
Did you check the tube? https://www.youtube.com/results?search_query=dowel+making+jig+
You didn’t ask, but I’ll tell you anyway. An easy way to line up dowels is to make a pattern. I make it just like making a gasket. Mark both sides for left and right just to be sure if they aren’t symmetric. It won’t work in every situation. Here’s one example where it did. http://lumberjocks.com/projects/56711
I like to use dowels with grooves when possible. I get them at big box hardware stores. For alignment, they might be a little loose, but they give a stronger joint.
And there are dowel plates for making dowels. Shop around, you might find a lower price than this.
https://www.lie-nielsen.com/product/dowel-plate-standard
-- My reality check bounced...
GR8HUNTER
#15 posted 01-09-2017 04:25 PM
- rwe2156
DITTO ^^^^^^^^^^^^^^^
i got mine from ebay for like 20.00 not a perfect 1 but as much as I use it…it works great for me….. also check craigslist…... and pawn shops …...and ebay and and
