Sanding walnut
Forum topic by Rick posted 08-25-2010 11:57 PM 7156 views 0 times favorited 13 replies Add to Favorites Watch
View Rick's profile
Rick
19 posts in 3609 days
08-25-2010 11:57 PM
Topic tags/keywords: walnut
So I pick a nice piece of walnut for the grain but when I sand it the grain pretty much disappears and the wood gets lighter in color, nothing like before it was sanded. The finish – usually tung oil – restores some of the color & detail, but I’m never happy with it. This happens every time I use walnut. I sand 110, 220, 320, regular sandpaper. Anyone have a suggestion?
Thanks
13 replies so far
16272 posts in 4092 days
#1 posted 08-26-2010 12:40 AM
I’m stumped, Rick. I use walnut all the time, and I have not seen what you are describing. I’m guessing that you are picking your walnut from stock that has been milled for a very long time, and has darkened with age from exposure to light, so sanding reveals “fresher” wood.
View BroDave's profile
BroDave
107 posts in 3688 days
#2 posted 08-26-2010 01:07 AM
Just expose it to sunlight for a couple of hours before you apply the finish, it will darken up again.
View Sawmillnc's profile
Sawmillnc
150 posts in 2928 days
#3 posted 08-26-2010 01:43 AM
Could be you are using steamed walnut instead of nice sawmill air dried then kiln dried walnut. If you buy from a retailer you have steamed.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
View Xtreme90's profile
Xtreme90
193 posts in 3066 days
#4 posted 08-26-2010 03:37 AM
try just sanding just to 150 then apply finish.
-- "I don't cut wood. I machine it!" G.M. The wood machinest
View Gofor's profile
Gofor
470 posts in 3660 days
#5 posted 08-26-2010 04:22 AM
You could also try a card scraper instead of sanding. It will give you the same surface quality as if you hand planed it. However, like Charlie, I have never had that result. I use air dried, though.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View richgreer's profile
richgreer
4541 posts in 2948 days
#6 posted 08-26-2010 04:23 AM
Just an idea – - try card scraping instead of sanding.
View Ollie's profile
Ollie
146 posts in 3148 days
#7 posted 09-03-2010 10:45 AM
I have noticed a similar effect recetly but i found once I applied oil fiinsh the grain came back very well.
I would say that if it is straight pieces then just plane it or use a scraper, thus avoiding sadpaper al together.
-- Ollie, UK.
View jusfine's profile
jusfine
2422 posts in 2799 days
#8 posted 09-03-2010 05:20 PM
From my experience, walnut color becomes lighter with age...
Cherry darkens.
I have never seen the “symptoms” you describe either.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Kathy's profile
Kathy
210 posts in 2795 days
#9 posted 09-04-2010 11:12 AM
I had the same experience with walnut that I used on a box. Also the finish never got really smooth. It seemed like there were little bits almost like the surface was “fuzzy”. I finally got a tolerable finish with poly, sand, poly sand, etc.
-- curious woodworker
View Bill White's profile
Bill White
4821 posts in 3834 days
#10 posted 09-04-2010 11:24 PM
Sounds like you have steamed walnut. Walnut will naturally lighten with light and age (not like cherry which gets darker).
Bill
-- bill@magraphics.us
View ChrisJohnson's profile
ChrisJohnson
3 posts in 2713 days
#11 posted 09-05-2010 04:45 AM
I agree with a few other post here that when you use air dryed walnut the color stands out more.
When ever you sand a piece of wood the air on it makes it look different after you place any stain or finish on it.
On a different note: you can use a mixture of vinager and steelwool If you want the wood to look more aged as one different process
View MOJOE's profile
MOJOE
548 posts in 3142 days
#12 posted 09-09-2010 04:20 AM
Just a guess, but walnut is somewhat open grained…...might be fine dust collecting in the pores and making things look washed out. Might try a quick wash with alcohol or the like and then blow dry with compressed air. The alcohol should also show you a “sneak peak” of how the wood will look when finished.
-- Measuring twice and cutting once only works if you read the tape correctly!
View 489tad's profile
489tad
3291 posts in 2885 days
#13 posted 09-10-2010 04:58 PM
I just cut and sanded a sample piece of walnut to see how it would look next to lacewood. Off the band saw, 60, 80, 120, 220. I spritzed with water to raise the grain and sanded with 220 again. Very smooth, and the sanded side is the same color as the original surface, one coat of oil and the grain popped. Sample is from Woodcraft so maybe its steamed? Good luck.
-- Dan, Naperville IL, I.G.N.
