Needs tips for making/inserting structural butterfly keys
Forum topic by Pete Tevonian posted 08-25-2010 05:31 PM 4589 views 0 times favorited 4 replies Add to Favorites Watch
View Pete Tevonian's profile
Pete Tevonian
78 posts in 2826 days
08-25-2010 05:31 PM
Topic tags/keywords: cookies drying butterfly keys
I have some large trunk cross-sections “cookies” that I’m trying to dry to make a coffee table and end table. I’m about halfway through the drying process, and a fairly significant crack has started to form starting from one edge and reaching about 1/3 of the way to the center of the cookie.
I expect I will need to add a butterlfy key to stop the progress of that crack. But I have questions, of course:
1. Will adding a key to stop this crack simply mean another crack will start elsewhere?
2. Is there a right or wrong time to add the key? I assume the sooner the better.
3. The cookie in question is 2.5” to 3” thick, and has a diameter ranging from 39” to 49” (thus a circumference of about 140”), so even 2% shrinkage could result in over 2” of gaps in cracks —how thick should the key be to provide the necessary support for that much wood/force? I’ve seen decorative butterflies discussed that are 1/8” to 3/16” thick. I can’t image that would be enough to hold this piece of wood. I’ve some posts talk about 1” deep mortises. And do I need butterlfies on top and bottom?
4. The whole cookie is end grain—I assume the key should have the grain running the length of the key, so that the forces pulling it appart will be pulling on the strong, long grain.
Thanks in advance for any guidance. I can post pics if that’s useful.
-- Pete in Wilmette, IL
View uffitze's profile
uffitze
199 posts in 2863 days
#1 posted 08-25-2010 08:17 PM
Yep. As wood dries it shrinks across the growth rings, so the outer edges of the wood are going to shrink more than the heart, and you are going to get cracks.
Given (1), I would wait until the thing is dry. But, if you want to limit the size of any one crack, then you could throw one in at any time.
I’d probably use one that is a bit beefier than 1/8” ... 3/4” or 1” would probably hold fine, but if the crack is big enough, you might want one that is full thickness just for aesthetic reasons.
Yep.
View ChrisMc45's profile
ChrisMc45
100 posts in 2768 days
#2 posted 08-06-2012 02:29 AM
butterflies on both sides of the crack, both sides of the slab. This will help avoid warping the slab.
I have no experience with ‘predictive” butterflies, but from UUFIZE comment, maybe a good idea to circle the whole thing with butterfly-joints an the non-show side? Strictly an “idea”, not a solution based on anything.
Bon chance!
CMc
View bondogaposis's profile (online now)
bondogaposis
4611 posts in 2259 days
#3 posted 08-06-2012 03:48 AM
The crack will stop on it’s own once it reaches the center. I wouldn’t try to stop it or other cracks will form somewhere else. You can’t really prevent it. It occurs because wood shrinkage in the tangential direction is roughly double the shrinkage in the radial direction. I’d wait until it is dry before butterflying it.
-- Bondo Gaposis
Pete Tevonian
#4 posted 08-07-2012 02:26 PM
Actually, I did use Pentacryl. It’s my first time, both drying wood myself and using pentacryl, but it does seem to work well. The entire slab is dry now, with only a total of 1/2” of gaps when all cracks are combined. And none of the cracks reaches the center of the slab. I did add two Walnut butterflies soon after I posted this thread, about 1” thick (or halfway through the thickness of the slab). As Chris warned above (although too late for me, :) ) the top did shift a bit after I added the butterflies. The bottom, unbutterflied side seems like it expanded a bit more than the butterflied side, so I have about 1/8” to 1/4” of curve across the 49” length. Not terrible, and actually, when screwed to it’s base it comes flat again. But it does seem like a full-thickness butterfly, or matching keys on both sides, would have been advisable.
The sad thing, in looking back at this thread, which I posted… 712 days ago? Can that be right??... is that I’m STILL working on this project! AAAAA! Time in the workshop is rare, and I’m doing a lot of thinking, planning and research so that I hopefully don’t screw up these unique pieces of wood. But I’m close! The base is just about done—needs a couple more coats of oil/varnish, and a bit of polishing. And the top has been grain-filled and is drying, waiting for more sanding, and the oil/varnish finish. I’ll post pics when I’m done.
