HELP! General Finishes Rosewood very VERY red
Forum topic by Jim posted 01-08-2017 02:45 PM 1183 views 2 times favorited 24 replies Add to Favorites Watch
View Jim's profile
Jim
119 posts in 1688 days
01-08-2017 02:45 PM
Topic tags/keywords: help stain red color finishing
Hey everyone, so I’ve got a problem. My client wanted a dark brown stain with a definite red tint to it on a recent sofa table commission. We both agreed a General Finishes Rosewood stain what appeared to match the clients existing wood tones in their home.
I don’t stain often, but I felt confident enough to do this for them. I applied according to the instructions, wiping off excess before moving onto the next area on the table.
It turned out, to put it nicely, incredibly RED. I’ve only done one coat, but after showing it to a friend, we both kind of agree it’s just too light. Looking at other peoples projects this tone comes through very very dark. I almost think it’s on the right track, but it’s just TOO light.
I’ve not put a top coat on yet. I’m planning on doing Arm-R-Seal.
The wood is red oak.
My options (I think):
1) do another coat
2) another coat, but let it soak in longer
3) stain with a dark brown over this.
4) burn the table
Will the Am-R-Seal darken the tone?
PLEASE HELP
I’m open to all ideas. I need to get this figured out today so I can top coat the next two days and deliver this week,
thanks so much in advance.
Jim
-- Jim from Rivertown Woodcraft | Grand Rapids, MI | www.YouTube.com/user/RivertownWoodcraft
24 replies so far
View waho6o9's profile
waho6o9
8207 posts in 2603 days
#1 posted 01-08-2017 03:00 PM
1) Practice on scraps first saving the recipes on the back
2) Present samples to customer and agree on the recipe.
3) Run a test sample on say the underside of the top and the customer will have a better idea of what to expect.
4) To get the dark brown color you’re after this might make your day:
5) You got this big guy no problem, easy peasy and good luck.
View Aj2's profile (online now)
Aj2
1439 posts in 1824 days
#2 posted 01-08-2017 03:21 PM
I agree with waho6o9. I’m also a General finish user.
Aj
-- Aj
View bondogaposis's profile
bondogaposis
4766 posts in 2377 days
#3 posted 01-08-2017 03:29 PM
Yes, wahoo has it right, always work out your finish schedule on scraps, before applying finish to a project. Using the pieces of wood from the project assures that the finish result won’t be hit or miss. Prep the sample pieces the same as the project.
-- Bondo Gaposis
View Jim's profile
Jim
#4 posted 01-08-2017 03:45 PM
Thanks everyone, yep, cutting corners trying to save money. I don’t normally stain so I wasn’t prepaired to buy a lot of different colors to sample them.
Is the Java a bit red? Can I go over my current situation with it? I have a couple of sampled from yesterday stained the same as the table, I will give staining over it with java a go.
There is a time crunch, but I have a few extra days I could potentially push back delivery so I’m not completely screwed.
Thanks again for the prompt responses. I’ll keep you all updated.
117120 posts in 3603 days
#5 posted 01-08-2017 03:48 PM
wahoo +3 and or Contact Charles Neil the best finish guy out there.
View Jim's profile
Jim
#6 posted 01-08-2017 03:50 PM
Thanks again guys.
Any idea why it’s not as dark as the samples shown on their website?
Again, my fault. You don’t learn unless you fall down sometimes. Time to pick myself up.
#7 posted 01-08-2017 03:56 PM
View Woodknack's profile (online now)
Woodknack
11793 posts in 2406 days
#8 posted 01-08-2017 05:22 PM
Don’t make it worse by experimenting on the table, get some scraps, stain them, then try different things.
View Jim's profile
Jim
#9 posted 01-08-2017 05:33 PM
Don t make it worse by experimenting on the table, get some scraps, stain them, then try different things.
- Rick M
definitely not going to. Already had a sample from yesterday, made in the small amount of time between staining the table and freaking out.
I’m going to divide it up with blue tape and try some things right now. I also picked up some java at woodcraft this morning.
If you guys want to follow along I’ll be venting on twitter. @RivertownWood
I’ll also update here later today
Jim
View Jim's profile
Jim
#10 posted 01-08-2017 07:17 PM
Did some tests with my sample. Included extra coats of the Rosewood I already started, as well as just applying Java over the Rosewood, and along those lines also including the different levels of sanding down the Rosewood finish.
I ended up going with a brushed on gel stain of java over top of brushing it on and not wiping it down with a rag let it be a thicker coat. It lets it’s become a really deep brown with a red tint. I’ll post some pictures once dry and then also after I apply armorseal.
Thanks again for the help guys.
#11 posted 01-08-2017 07:29 PM
Got photos ?
View Jim's profile
Jim
#12 posted 01-08-2017 08:19 PM
#13 posted 01-08-2017 08:27 PM
Looks good thanks for the photos
waho6o9
#14 posted 01-08-2017 08:33 PM
You passed the audition, Congratulations!
View bbasiaga's profile
bbasiaga
1234 posts in 2021 days
#15 posted 01-08-2017 08:41 PM
that is a great look on red oak….GF rosewood under Java. I’ll have to try that.
