How to dry?
Forum topic by Hippockets posted 08-25-2010 03:28 AM 1128 views 0 times favorited 4 replies Add to Favorites Watch
View Hippockets's profile
Hippockets
93 posts in 3013 days
08-25-2010 03:28 AM
I have an oppurtunity to get some Eastern red cedar cut to 15”dia by 20” long. Can I resaw these into rectangles for storage purposes and let them dry in the large rectangles. I want to make bandsaw boxes when dry.
-- Bruce, Arnold MD bjordan443@aol.com
View Bill Davis's profile
Bill Davis
226 posts in 3830 days
#1 posted 08-25-2010 04:35 AM
I’m sure you can. My recommendation is to not allow them to dry too rapidly or you will very like have many pieces crack and split. If you can control the drying rate that will go a long way toward preventing that. I would also seal the end grain as the wood will dry fastest from there.
View MOJOE's profile
MOJOE
548 posts in 3175 days
#2 posted 08-25-2010 04:35 AM
I recently sawed some figured logs into rectangles and coated with anchor seal. Every piece checked horribly. I think it has to do with opening the inner portion of the wood up too quickly, and giving it the ability to dry quickly from all sides rather than just the ends. All other logs I have collected get coated on the ends and the bard left in place. It will take longer to dry, but should only give you light checking of the end grain.
-- Measuring twice and cutting once only works if you read the tape correctly!
View Eagle1's profile
Eagle1
2066 posts in 2971 days
#3 posted 08-26-2010 11:06 AM
I wouldn’t resaw them yet. I would put anchor seal on the ends of the logs, let them dry for a while before cutting. When you open all of that grain every where cedar will crack bad.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
Bill Davis
#4 posted 08-26-2010 11:38 AM
Or you could read some expert advice here from Dr. Wengert is Professor Emeritus in Wood Processing, Department of Forestry, at the University of Wisconsin (Madison) on this very topic.
